Art project help - quite a noob
Hello guys!
I'm quite new to Photon and coding as well.
We're are trying to build a controller for an art piece and the eletronic part should be really simple:
We need to press one (or more) button on one Photon, in London, and light an (or more) assigned LED on a Photon in Congo. This has to be as Real Time as possible.
My questions at the moment are:
-Can I publish directly to another device or do I need IFTTT for this?
-Should I use Publish Event or Call a Function
These are the codes I have so far:
Publishing Photon:
int led = D7; // Uses inbuilt LED
int pushButton = D1; // Push button is connected to D1
// This routine runs only once upon reset
  pinMode(led, OUTPUT); // Initialize D7 pin as output
  pinMode(pushButton, INPUT_PULLUP);
  // Initialize D1 pin as input with an internal pull-up resistor
// This routine loops forever
  int pushButtonState;
  pushButtonState = digitalRead(pushButton);
  if(pushButtonState == LOW)
  { // If we push down on the push button
    digitalWrite(led, HIGH);  // Turn ON the LED
    Spark.publish("pushButtonState","Pressed",60,PRIVATE);
    // Add a delay to prevent getting tons of emails from IFTTT
    delay(300);
  else
    digitalWrite(led, LOW);   // Turn OFF the LED
Subscribing Photon:
int led_green = D1;
int led_yellow = D2;
    pinMode(led_green, OUTPUT);
    pinMode(led_yellow, OUTPUT);
    Serial.println(Spark.subscribe("pressButton1State", greenOn, "230043000547343232363230"));
    Serial.println(Spark.subscribe("pressButton2State", yellowOn));
    delay(200);
void greenOn(const char *event, const char *data)
    digitalWrite(D7, HIGH);
void yellowOn(const char *event, const char *data)
This pretty much does what you’re looking for, without having to go through IFTTT.
Do update it from “spark” to “particle” if you would:
I’m not sure that this line of code actually works (despite the docs)
Unless I missed the memo, subscribing to events of a particular device is not yet supported.
You’d rather use
 Serial.println(Particle.subscribe("pressButton1State", greenOn, MY_DEVICES));
and secondly, you’d need to subscribe to an event that starts with a common prefix, but you do
while publishing
So you’d rather subscribe to
 Serial.println(Particle.subscribe("pushButtonState", someLedOn, MY_DEVICES));
then you only need one handler that deals with all kinds of published events (by evaluating the event name and data parameters) that start with "pushButtonState" like these
Particle.publish("pushButtonStateGreen","Pressed", PRIVATE);
// or
Particle.publish("pushButtonStateYellow","Pressed", PRIVATE);
// or
Particle.publish("pushButtonState","Yellow Pressed", PRIVATE);
And you should use a way to prevent multiple publishes when you press and hold the button and also ensure that you heed the one per second rate limit for Particle.publish() - delay(300) might be too short for that.
Thank you for the quick reply ScruffR!
So you're saying I should use IFTTT? (don't really know how to use webhooks)
This is really interesting. I think I understand what you mean.
so if I do:
if(pushButtonState1 == LOW)
    Particle.publish("pushButtonState","Green pressed",PRIVATE);
    delay(500);
on the Publishing and:
Serial.println(Particle.subscribe("pressButtonState", someLedOn, MY_DEVICES));
How can I determine which LED to turn on (just by the content "Green pressed" of the event)?
Nope, I don't. I just said that way to subscribe to your own publish would not work.
exactly - by ...
... e.g. like this
void someLedOn(const char *event, const char *data)
   if (!strcmp(data, "Green pressed"))  // if there is zero difference between the two strings
    digitalWrite(greenLedPin, HIGH);    // light up
Although I'd rather use numeric values instead of string literals
This is great, I was trying something similar but obviously didn't think of that.
Should I just replace
for
Particle.publish("pushButtonState",1,PRIVATE);
then or something similar?
How could I go about it if not IFTTT then?
(sorry again, complete noob here)
Almost there I think! Thank for the help so far anyway!
The code as is does already play without IFTTT - no extra work needed.
That would be sort of it, but the 1 would need to be a string (which will be converted back to an int again in the handler) and the real power of that would be unleashed when making that dynamic.
like this
  char evtData[32];
  int btnNr;
  // somehow get the pressed button number into btnNr
  snprintf(evtData, sizeof(evtData), "%d", btnNr); // that can even be more complex for multiple infos in one event
  Particle.publish("pushButtonState", evtData, PRIVATE);
and on the receiving end
  int btnNr = atoi(data);  // convert string back to int
  switch(btnNr)
    case 1:
      // do something for button 1 like
      break;
    case 2;
      // do something for button 2
      break;
    default:
      break;
