I have a ‘print’ function exposed via the cloud API for testing my font rendering code, so I can run “spark call print ‘Some text’” and have it displayed on the screen I have attached to my core, and it seems that the string that’s passed can’t seem to contain an ampersand - it gets replaced with a null byte.
I noticed that if you use curl to make the call manually, you can use URL encoding so that, for example, ‘%20’ is replaced with ’ ', and I’ve tried that with ‘%26’, for ‘&’, but it’s the same deal; it gets replaced with a null byte.
I noticed this too when sending strings to the message torch, my workaround was to replace the ampersand character with another unused one like an A with a dots above it… and have the core swap it back when sent to the display. I also used the same method for smilies, hearts and symbols. it also helped to reduce the number of characters sent to the function.
If you look at the message torch code there is this section to re-map the 16bit character, 0xC3 is the first byte of those characters and 0x84 is the second byte for the Ä character…
if (aText[i]==0xC3) {
if ((int)aText.length()<=i+1) break; // end of text
switch (aText[i+1]) {
case 0x84: c = 0x80; break; // Ä
case 0x96: c = 0x81; break; // Ö
case 0x9C: c = 0x82; break; // Ü
case 0xA4: c = 0x83; break; // ä
case 0xB6: c = 0x84; break; // ö
case 0xBC: c = 0x85; break; // ü
default: c = 0x7F; break; // unknown
i += 1;
Interesting idea, but no: it results in the function receiving "%26", which I guess is what I'd expect.
Yes, if I end up deciding it's important (and if it's not changed in the mean time) I'll probably do the same. For the moment it's not crucial as I'm only using the cloud function for testing.
