Argon sleeping mode
Hello I did some tests to use the sleeping commands, I can't understand why,
if I activate the sleeping method (hibernate or stop) it doesn't publish on the console.
Code:
// Include Particle Device OS APIs
#include "Particle.h"
int ledPin = D7;
// Let Device OS manage the connection to the Particle Cloud
SYSTEM_MODE(AUTOMATIC);
int PressV=30;
 pinMode(ledPin, OUTPUT);     // sets the pin as output
 Particle.variable("PressV",PressV);
void loop(){
Particle.publish("PressV",PressV);
  digitalWrite(ledPin,HIGH);
  delay(5000);
  digitalWrite(ledPin,LOW);
  delay(1000);
/*SystemSleepConfiguration config;
config.mode(SystemSleepMode::HIBERNATE)
      .gpio(D2, RISING);
System.sleep(config);*/
config.mode(SystemSleepMode::STOP)
      .gpio(D2, FALLING)
      .duration(30000);
What version of Device OS are you targeting? If 6.2.0 or later, that should work. If earlier, you should also enable
SYSTEM_THREAD(ENABLED);
Due to the way delay() works in non-threaded mode, it's possible that the publish does not complete before sleep.
The other thing that could help is adding the WAIT_CLOUD flag to make sure the publish completes before sleep:
      .flag(SystemSleepFlag::WAIT_CLOUD)
      .duration(15min);
[quote="rickkas7, post:2, topic:69717"]
.duration(15min);
[/quote]
Thanks for the suggestions, I have done the changes but nothing is published to the console using the SystemSleepConfiguration, doing a rem to these steps works. For your info I have an Argon the firmware version is 6.2.1.
Does it publish if you remove the sleep? Don't leave it that way too long since you'll use a lot of data operations publishing every 6 seconds.
You could also add:
and monitor the output using particle serial monitor --follow to see what's going on.
Yes it will be published if I remove the suspension, unfortunately I can't do anything for a week, I'll start working on it again when I get back. Thanks
Oh, think I see what's wrong. If you are using Device OS 6.2.0 or later, or SYSTEM_THREAD(ENABLED), at least the first publish occurs before you've connected to the cloud so it fails, then you go to sleep. Try inserting before the Particle.publish call in loop():
if (!Particle.connected()) {
  return;
Hello I implemented what you suggested and it works Thanks
