Application failing after adding new WiFi credentials; Photon
I have an application running on a Photon for two years without any problems.
Recently I added two new WiFi network credentials through the Setup sequence.
Since then, the application seems to fail on the retained variables I am using in the program.
Could that be caused by adding these two new WiFi networks??? (due to memory allocation or whatever)???
Note: I only added these two new networks and did not renew the application software on the device.
