App that gives access to Particle variables, events and function
Is there an (android) app that implements the API requests to access variables, functions and published events with a friendly UI? Particle cloud functions are simple, already built in the firmware and dependable.
I don’t like to add Blynk code and overhead into my application although the app is very nice and easy to use, and I gave up on building a simple webpage with javascript because I don’t have a secure hosting solution.
{IFTTT+DO button } do the job but it’s two apps and IFTTT increases energy consumption on my phone because it connects frequently. I want an app that connects only when I open it, to check status and change settings when needed.
I’ve searched the forum with no success, so if you have solutions please enlighten me!
Hi @jaafar,
Hmm, you could use the Tinker App for Android as a starting point:
Or the mobile SDK for Android here:
David
Hi @jaafar,
I’ll be publicly releasing an app like this for Android (and iOS) within a few weeks. Get in touch if you’re interested in testing it out.
Cheers,
Larry
