Any way to get particle/electron battery voltage?
Also I’m interested in getting cellular signal strength on the Electron. Thanks
And which parts of the docs did you have problems with? Both of these are documented as far as I’m aware.
I could not find it. Trust me, I’d rather search docs than post. Thanks
To answer your question, I searched in Electron Firmware.
Is anyone willing to divulge where this is in the documents?
Thanks.
Which is exactly where it's documented.
https://docs.particle.io/reference/firmware/electron/#rssi-
https://docs.particle.io/reference/firmware/electron/#fuelgauge
Thanks. Forgive me for my mistake.
