Android app stuck on "connecting to photon" (SOLVED)
Hi Mora
Thanks for considering my problem.
Yes I did try to connect my photon with another cable on my PC. The results remains the same.
To be fully complete:
  • I first had this problem during the first 2 hours I tried
  • Second day, with the same procedure, it suddenly became possible to go further, until the last connection step, where it failed : setup process could’nt claim your photon,and the LED was breathing cyan (probably the same problem described in this post Connection to Photon [SOLVED]).
  • Then today, I even can’t go further the first connection step, I remain stuck. Quiet strange because I think I went through the same procedure than the day before…
You have the whole story…
