I am using a air quality sensor (Co2) that has an analog linear output of 0 - 4 volts and some others 0-5V. I do not want affect the accuracy. What do you recommend me for working with Boron device?
Do you mean you will sometimes be using the 0-4V and other times 0-5V versions?? I have not been in this very long and in my humble opinion, I would advise against doing so…
I had a similar situation but with current sensing (5A, 10A and 20A versions) and ended up reverting everything to the 20A sensors in order to simplify things.
