Amperage or resistance of D0 pin
Does anyone know the amperage or resistance of the D0 pin when it is at 3.3V (HIGH)?
The max current any GPIO pin can source or sink is rated with 25mA and the minimum if all GPIOs are on is rated with 8mA.
That’s what the datasheets section is for in the docs
https://docs.particle.io/datasheets
@ScruffR, the total GPIO allowable current is 120ma, not 8ma :wink:
@peekay123 I think @ScruffR meant the minimum current you’re guaranteed to get if you’re driving all pins. The 8 would be your 120/(all active pins)
