ADC sample rate for best series resistor practice on Electron
In the STM32F205RGT6 datasheet, there is a formula for the recommended R_AIN external input impedance for the ADC pin for lowest noise.
Page 126 of the datasheet:
The only thing that isn’t known is the k factor from the value of the ADC_SMPR1 register (page 334): http://www.st.com/content/ccc/resource/technical/document/reference_manual/group0/4f/7b/2b/bd/04/b3/49/25/DM00180369/files/DM00180369.pdf/jcr:content/translations/en.DM00180369.pdf
Can someone from Particle confirm what they set this register to in the default firmware?
I’m pretty sure the ADC_SMPR1 register is the sample time value.
The default value is 480, but you can it to other values.
https://docs.particle.io/reference/firmware/electron/#setadcsampletime-
Yep, those numbers line up exactly with the options in the second PDF link. Thanks!
This is the approximate input impedance of the ADC so you should drive it with a much lower impedance source to get good operation. Using a source impedance as high as R_ain will almost guarantee poor results.
This is a not a resistor you put in series with the input, as the title of the thread suggests.
Correct, it’s really a maximum, and by series resistor, it’s probably better described as the Thevenin equivalent series resistance of the source feeding the pin.
