Accuracy of ADC at higher rate on E - Series
I have been trying to get accurate ADC reading at 16KHz sampling rate. I am using SparkIntervalTimer library to get the sampling rate. Due to higher sampling rate, I have set the ADC sampling time to 56 Cycles.
Here’s the code I used to get the data.
#include <SparkIntervalTimer.h>
#include "Particle.h"
#include <math.h>
IntervalTimer ReadADC;
volatile uint16_t raw_data[8000], i = 0, ADCSample = 0;
volatile bool SampleFlag = true;
const int PIN_AIN = A1;
SYSTEM_THREAD(ENABLED);
void Toggle(void)
    if(SampleFlag)
		raw_data[ADCSample++] = HAL_ADC_Read(PIN_AIN);
    if(ADCSample == 8000)
		  SampleFlag = false;
  pinMode(PIN_AIN, INPUT);
  Serial1.begin(9600);
  setADCSampleTime(ADC_SampleTime_56Cycles);
  ReadADC.begin(Toggle, 61, uSec);
    if(!SampleFlag)
        for(i = 0; i < 8000; i++)
            Serial1.println(raw_data[i]);
			raw_data[i] = 0;
        SampleFlag = true;
Note: Ignore the code error if found. I pasted the code without testing but this is the same code(logically) I have used to get the data.
Hardware used:
  • E series development board
  • Powered with stable 5V VIN instead of USB or battery.
  • 1.24V stable DC applied to the A1 Pin.
  • Internal 3.3V as a reference voltage.
I logged approx 15000 samples and plotted on the graph which helped me find that ADC does fluctuate a lot. I have no idea what is causing this fluctuation. Power supply is for sure stable as it was from a lab power supply.
Here’s the data:
Untitled
Is this the limitation of ADC? All suggestions and help are welcomed.
It looks like a variation of 10 out of a scale of 0-4095. That’s +/- 0.004028 volts, which doesn’t seem like that big of a variation to me. However, this application note explains how to get the best performance out of the ADC:
