Adafruit Thermal Library Error
Device: Particle PHOTON
Particle IDE: build.particle.io
Attempting to flash the adafruit_thermal code to the particle photon, which has the library included, returns errors which I’ve included an image of.
Without seeing your code, or the full error, I’m afraid there’s not much we can do. Please give us the full steps, and information needed to reproduce the problem.
Here is my code :
#include <Adafruit_Thermal.h>
Adafruit_Thermal printer;
// String tweet;
char tweet[300];
String oldTweet;
void setup(){
  Serial.begin(9600); // Uses regular serial
  Serial1.begin(19200); //Starts printer serial (RX (green printer wire), TX (yellow printer wire)
  printer.begin(&Serial1); //uses RX and TX
  Particle.subscribe("Treytest", myHandler); //subscribes to the event
   printer.println(tweet);
   printer.feed(1);
//empty
void myHandler(String event, String data) {
  /* Particle.subscribe handlers are void functions, which means they don't return anything.
  They take two variables-- the name of your event, and any data that goes along with your event.
  In this case, the event will be "buddy_unique_event_name" and the data will be "intact" or "broken"
  Since the input here is a char, we can't do
     data=="intact"
    or
     data=="broken"
  chars just don't play that way. Instead we're going to strcmp(), which compares two chars.
  If they are the same, strcmp will return 0.
  Particle.publish("myhandlerBlue Triggered", "YES"); //Debug - let me know it was triggered
  int result = data.compareTo(oldTweet); //compares to old tweet
  if (result == 0) {
    Particle.publish("Blue_the_same", "Samesies");
    } else {
    // if the data is something else
      printReal(data); //sends this to the printing function
      oldTweet = String(data); //saves this tweet in oldTweet
      Particle.publish("Blue_the_same", "Not The Same"); //publish a message
    void printReal(String thing) { //the printer function
        printer.wake();
        printer.boldOn();
        Particle.publish("thing_I_printed_blue", thing);
        printer.println(thing);
        printer.feed(8); //8 lines are enough to clear the opening
        printer.sleep();
void print2(String event, String data) {
    printer.wake();
    printer.inverseOn();
    printer.println(data);
    printer.inverseOff();
    printer.feed(8);
    printer.sleep();
    Particle.publish("thing_I_printed_blue", data);
Particle.subscribe() handlers should look like this tho'
https://docs.particle.io/reference/firmware/photon/#particle-subscribe-
And you should not Particle.publish() inside the handler before saving away event and data if you want to use them later on.
