Hello everyone. I am having issues setting up the Adafruit OLED FeatherWing 128x32 display. Every time that I compile, it produces several errors, notably:
warning: "ARDUINO" is not defined
error: class 'Adafruit_SSD1306' does not have any field named 'restoreClk'
178 | wireClk(clkDuring), restoreClk(clkAfter) {
#define WIRE_WRITE wire->send ///< Wire write function in older Arduino lib
See terminal log, below.
I am trying to flash the default demo code that is included in the manual for OLED (LINK). This text will be hidden
Do I need to downgrade my OS firmware version for the project/Argon board? I have read through several other feeds and was unable to find a solution.
:::: PUTTING DEVICE INTO DFU MODE
Done.
:::: FLASHING APPLICATION
Creating /Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/target/2.0.0/argon/platform_user_ram.ld ...
In file included from /Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/src/Test_2.ino:12:
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.h:41: warning: "SPI_HAS_TRANSACTION" redefined
41 | #define SPI_HAS_TRANSACTION
In file included from ./inc/application.h:95,
from ./inc/Particle.h:5,
from /Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2//src/Test_2.cpp:5:
../wiring/inc/spark_wiring_arduino.h:76: note: this is the location of the previous definition
76 | #define SPI_HAS_TRANSACTION (1)
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.h:44: warning: "SPI_HAS_TRANSACTION" redefined
44 | #define SPI_HAS_TRANSACTION 1
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.h:41: note: this is the location of the previous definition
In file included from /Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:52:
from /Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_GFX/src/Adafruit_GFX.h:4,
from /Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:51:
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.h:201:5: warning: "ARDUINO" is not defined, evaluates to 0 [-Wundef]
201 | #if ARDUINO >= 157
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:68:5: warning: "ARDUINO" is not defined, evaluates to 0 [-Wundef]
68 | #if ARDUINO >= 100
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:86:6: warning: "ARDUINO" is not defined, evaluates to 0 [-Wundef]
86 | #if (ARDUINO >= 157) && !defined(ARDUINO_STM32_FEATHER)
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp: In constructor 'Adafruit_SSD1306::Adafruit_SSD1306(uint8_t, uint8_t, TwoWire*, int8_t, uint32_t, uint32_t)':
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:178:3: error: class 'Adafruit_SSD1306' does not have any field named 'wireClk'
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:178:23: error: class 'Adafruit_SSD1306' does not have any field named 'restoreClk'
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp: In member function 'void Adafruit_SSD1306::ssd1306_command1(uint8_t)':
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:71:27: error: 'class TwoWire' has no member named 'send'; did you mean 'end'?
71 | #define WIRE_WRITE wire->send ///< Wire write function in older Arduino lib
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:373:5: note: in expansion of macro 'WIRE_WRITE'
373 | WIRE_WRITE((uint8_t)0x00); // Co = 0, D/C = 0
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:374:5: note: in expansion of macro 'WIRE_WRITE'
374 | WIRE_WRITE(c);
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp: In member function 'void Adafruit_SSD1306::ssd1306_commandList(const uint8_t*, uint8_t)':
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:387:5: note: in expansion of macro 'WIRE_WRITE'
387 | WIRE_WRITE((uint8_t)0x00); // Co = 0, D/C = 0
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:393:9: note: in expansion of macro 'WIRE_WRITE'
393 | WIRE_WRITE((uint8_t)0x00); // Co = 0, D/C = 0
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:396:7: note: in expansion of macro 'WIRE_WRITE'
396 | WIRE_WRITE(pgm_read_byte(c++));
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp: In member function 'void Adafruit_SSD1306::display()':
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:918:5: note: in expansion of macro 'WIRE_WRITE'
918 | WIRE_WRITE((uint8_t)0x40);
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:924:9: note: in expansion of macro 'WIRE_WRITE'
924 | WIRE_WRITE((uint8_t)0x40);
/Users/michael/OneDrive/Projects/Capstone_Code/Test_Dist/Test_2/lib/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.cpp:927:7: note: in expansion of macro 'WIRE_WRITE'
927 | WIRE_WRITE(*ptr++);
make[3]: *** [../build/target/user/platform-12-m/Test_2/Adafruit_SSD1306_RK/src/Adafruit_SSD1306.o] Error 1
make[2]: *** [user] Error 2
make[1]: *** [modules/argon/user-part] Error 2
make: *** [flash-user] Error 2
The terminal process "/bin/bash '-c', 'make -f '/Users/michael/.particle/toolchains/buildscripts/1.9.2/Makefile' flash-user -s'" terminated with exit code: 2.
