After a bit of fiddling, I got MIDI working on the Adafruit Music Maker VS1053 feather wing.
The hardware Serial1 port needs to be used, and set to 31250. This doesn’t work out of the box, so the way around it is to assign a baud rate and then change that to 31250. I figured this out by looking at another example that showed how to use custom baud rates.
// Solder closed jumper on bottom!
// See http://www.vlsi.fi/fileadmin/datasheets/vs1053.pdf Pg 31
#define VS1053_BANK_DEFAULT 0x00
#define VS1053_BANK_DRUMS1 0x78
#define VS1053_BANK_DRUMS2 0x7F
#define VS1053_BANK_MELODY 0x79
// See http://www.vlsi.fi/fileadmin/datasheets/vs1053.pdf Pg 32 for more!
#define VS1053_GM1_SOUND 27
#define MIDI_NOTE_ON 0x90
#define MIDI_NOTE_OFF 0x80
#define MIDI_CHAN_MSG 0xB0
#define MIDI_CHAN_BANK 0x00
#define MIDI_CHAN_VOLUME 0x07
#define MIDI_CHAN_PAN 0x0A
#define MIDI_CHAN_PITCH 0xE0
#define MIDI_EFFECT_CNTRL 0x0C
#define MIDI_EFFECT_LEVEL 0x5B
#define MIDI_CHAN_PROGRAM 0xC0
#define VS1053_MIDI Serial1
#define UARTE0_BASE_ADDR 0x40002000 // As per nRF52840 Product spec - UARTE
#define UART_BAUDRATE_REG_OFFSET 0x524 // As per nRF52840 Product spec - UARTE
#define UART0_BAUDRATE_REGISTER (*(( unsigned int *)(UARTE0_BASE_ADDR + UART_BAUDRATE_REG_OFFSET)))
/* from nRF52840 Product spec - a baud rate of 31250 uses a register value of 0x00800000 */
#define BAUDRATE_31250 0x00800000
boolean bPlayOnce = true;
// NOTE: UART0 is attached to Serial1. Serial is attached to USB
VS1053_MIDI.begin(19200);
// original values - used to verify that we are looking at the correct registers
Serial.print("Original UART0 Baud rate: 0x");
Serial.println(UART0_BAUDRATE_REGISTER,HEX);
// change the baud rate
UART0_BAUDRATE_REGISTER = BAUDRATE_31250;
// Verify the change
Serial.print("Updated UART0 Baud rate: 0x");
Serial.println("VS1053 MIDI test");
midiSetChannelBank(0, VS1053_BANK_DRUMS1);
midiSetChannelVolume(0, 40);
midiSetInstrument(0, VS1053_GM1_SOUND);
midiSetPan(0,127);
midiSetReverbType(0,127);
midiSetReverbLevel(0,64);
if(bPlayOnce)
for (uint8_t i=0; i < 5; i++) {
if(i%2==0)
midiSetPan(0,0);
else
midiSetPan(0,127);
delay(5);
midiNoteOn(0, 56, 127);
delay(200);
midiNoteOff(0, 56, 127);
delay(500);
bPlayOnce = false;
void midiSetInstrument(uint8_t chan, uint8_t inst) {
if (chan > 15) return;
inst --; // page 32 has instruments starting with 1 not 0 :(
if (inst > 127) return;
VS1053_MIDI.write(MIDI_CHAN_PROGRAM | chan);
delay(10);
VS1053_MIDI.write(inst);
delay(10);
void midiSetChannelVolume(uint8_t chan, uint8_t vol) {
if (vol > 127) return;
VS1053_MIDI.write(MIDI_CHAN_MSG | chan);
VS1053_MIDI.write(MIDI_CHAN_VOLUME);
VS1053_MIDI.write(vol);
void midiSetChannelBank(uint8_t chan, uint8_t bank) {
if (bank > 127) return;
VS1053_MIDI.write((uint8_t)MIDI_CHAN_BANK);
VS1053_MIDI.write(bank);
void midiNoteOn(uint8_t chan, uint8_t n, uint8_t vel) {
if (n > 127) return;
if (vel > 127) return;
VS1053_MIDI.write(MIDI_NOTE_ON | chan);
VS1053_MIDI.write(n);
VS1053_MIDI.write(vel);
void midiNoteOff(uint8_t chan, uint8_t n, uint8_t vel) {
VS1053_MIDI.write(MIDI_NOTE_OFF | chan);
void midiSetPan(uint8_t chan, uint8_t pan) {
VS1053_MIDI.write(MIDI_CHAN_PAN);
VS1053_MIDI.write(pan);
void midiSetReverbLevel(uint8_t chan, uint8_t amount) {
VS1053_MIDI.write(MIDI_EFFECT_LEVEL);
VS1053_MIDI.write(amount);
void midiSetReverbType(uint8_t chan, uint8_t amount) {
VS1053_MIDI.write(MIDI_EFFECT_CNTRL);
VS1053_MIDI.write(amount); // 0 = auto, 1..127 = increasing reverb room size (I think ?)
Maybe this is of interest to the gen3 VS1053 library examples @ScruffR @peekay123 ?
