Adafruit LSM303 pushing Variable into the cloud
Hi Guys,
I have this code for Adafruit LSM303 acceleromter sensor.
I want to be able to “access” member function data i.e X,Y,Z values and be able to push them into the cloud using Particle.variable().
Can someone help me with this please?
    #include "Adafruit_Sensor.h"
#include "Adafruit_LSM303_U.h"
/* Assign a unique ID to this sensor at the same time */
Adafruit_LSM303_Accel_Unified accel = Adafruit_LSM303_Accel_Unified(54321);
void displaySensorDetails(void)
  sensor_t sensor;
  accel.getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" m/s^2");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" m/s^2");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" m/s^2");
  Serial.println("");
  delay(500);
void setup(void)
  Serial.println("Accelerometer Test"); Serial.println("");
  /* Initialise the sensor */
  if(!accel.begin())
    /* There was a problem detecting the ADXL345 ... check your connections */
    Serial.println("Ooops, no LSM303 detected ... Check your wiring!");
    while(1);
  /* Display some basic information on this sensor */
  displaySensorDetails();
void loop(void)
  /* Get a new sensor event */
  sensors_event_t event;
  accel.getEvent(&event);
  /* Display the results (acceleration is measured in m/s^2) */
  Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print("  ");
  Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print("  ");
  Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print("  ");Serial.println("m/s^2 ");
  delay(500);
And here’s the .cpp logic
  This is a library for the LSM303 Accelerometer and magnentometer/compass
  Designed specifically to work with the Adafruit LSM303DLHC Breakout
  These displays use I2C to communicate, 2 pins are required to interface.
  Adafruit invests time and resources providing this open source code,
  please support Adafruit andopen-source hardware by purchasing products
  from Adafruit!
  Written by Kevin Townsend for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <limits.h>
static float _lsm303Accel_MG_LSB     = 0.001F;   // 1, 2, 4 or 12 mg per lsb
static float _lsm303Mag_Gauss_LSB_XY = 1100.0F;  // Varies with gain
static float _lsm303Mag_Gauss_LSB_Z  = 980.0F;   // Varies with gain
 ACCELEROMETER
 PRIVATE FUNCTIONS
    @brief  Abstract away platform differences in Arduino wire library
void Adafruit_LSM303_Accel_Unified::write8(byte address, byte reg, byte value)
  Wire.beginTransmission(address);
  Wire.write((uint8_t)reg);
  Wire.write((uint8_t)value);
  Wire.endTransmission();
byte Adafruit_LSM303_Accel_Unified::read8(byte address, byte reg)
  byte value;
  Wire.requestFrom(address, (byte)1);
  value = Wire.read();
  return value;
    @brief  Reads the raw data from the sensor
void Adafruit_LSM303_Accel_Unified::read()
  // Read the accelerometer
  Wire.beginTransmission((byte)LSM303_ADDRESS_ACCEL);
  Wire.write(LSM303_REGISTER_ACCEL_OUT_X_L_A | 0x80);
  Wire.requestFrom((byte)LSM303_ADDRESS_ACCEL, (byte)6);
  // Wait around until enough data is available
  while (Wire.available() < 6);
  uint8_t xlo = Wire.read();
  uint8_t xhi = Wire.read();
  uint8_t ylo = Wire.read();
  uint8_t yhi = Wire.read();
  uint8_t zlo = Wire.read();
  uint8_t zhi = Wire.read();
  // Shift values to create properly formed integer (low byte first)
  _accelData.x = (int16_t)(xlo | (xhi << 8)) >> 4;
  _accelData.y = (int16_t)(ylo | (yhi << 8)) >> 4;
  _accelData.z = (int16_t)(zlo | (zhi << 8)) >> 4;
 CONSTRUCTOR
    @brief  Instantiates a new Adafruit_LSM303 class
Adafruit_LSM303_Accel_Unified::Adafruit_LSM303_Accel_Unified(int32_t sensorID) {
  _sensorID = sensorID;
 PUBLIC FUNCTIONS
    @brief  Setups the HW
bool Adafruit_LSM303_Accel_Unified::begin()
  // Enable I2C
  Wire.begin();
  // Enable the accelerometer (100Hz)
  write8(LSM303_ADDRESS_ACCEL, LSM303_REGISTER_ACCEL_CTRL_REG1_A, 0x57);
  return true;
    @brief  Gets the most recent sensor event
void Adafruit_LSM303_Accel_Unified::getEvent(sensors_event_t *event) {
  /* Clear the event */
  memset(event, 0, sizeof(sensors_event_t));
  /* Read new data */
  read();
  event->version   = sizeof(sensors_event_t);
  event->sensor_id = _sensorID;
  event->type      = SENSOR_TYPE_ACCELEROMETER;
  event->timestamp = millis();
  event->acceleration.x = _accelData.x * _lsm303Accel_MG_LSB * SENSORS_GRAVITY_STANDARD;
  event->acceleration.y = _accelData.y * _lsm303Accel_MG_LSB * SENSORS_GRAVITY_STANDARD;
  event->acceleration.z = _accelData.z * _lsm303Accel_MG_LSB * SENSORS_GRAVITY_STANDARD;
    @brief  Gets the sensor_t data
void Adafruit_LSM303_Accel_Unified::getSensor(sensor_t *sensor) {
  /* Clear the sensor_t object */
  memset(sensor, 0, sizeof(sensor_t));
  /* Insert the sensor name in the fixed length char array */
  strncpy (sensor->name, "LSM303", sizeof(sensor->name) - 1);
  sensor->name[sizeof(sensor->name)- 1] = 0;
  sensor->version     = 1;
  sensor->sensor_id   = _sensorID;
  sensor->type        = SENSOR_TYPE_ACCELEROMETER;
  sensor->min_delay   = 0;
  sensor->max_value   = 0.0F; // TBD
  sensor->min_value   = 0.0F; // TBD
  sensor->resolution  = 0.0F; // TBD
 MAGNETOMETER
 PRIVATE FUNCTIONS
void Adafruit_LSM303_Mag_Unified::write8(byte address, byte reg, byte value)
byte Adafruit_LSM303_Mag_Unified::read8(byte address, byte reg)
  byte value;
  return value;
void Adafruit_LSM303_Mag_Unified::read()
  // Read the magnetometer
  Wire.beginTransmission((byte)LSM303_ADDRESS_MAG);
  Wire.write(LSM303_REGISTER_MAG_OUT_X_H_M);
  Wire.requestFrom((byte)LSM303_ADDRESS_MAG, (byte)6);
  // Note high before low (different than accel)
  _magData.x = (int16_t)(xlo | ((int16_t)xhi << 8));
  _magData.y = (int16_t)(ylo | ((int16_t)yhi << 8));
  _magData.z = (int16_t)(zlo | ((int16_t)zhi << 8));
  // ToDo: Calculate orientation
  _magData.orientation = 0.0;
 CONSTRUCTOR
Adafruit_LSM303_Mag_Unified::Adafruit_LSM303_Mag_Unified(int32_t sensorID) {
  _autoRangeEnabled = false;
 PUBLIC FUNCTIONS
bool Adafruit_LSM303_Mag_Unified::begin()
  // Enable I2C
  Wire.begin();
  // Enable the magnetometer
  write8(LSM303_ADDRESS_MAG, LSM303_REGISTER_MAG_MR_REG_M, 0x00);
  // Set the gain to a known level
  setMagGain(LSM303_MAGGAIN_1_3);
  return true;
    @brief  Enables or disables auto-ranging
void Adafruit_LSM303_Mag_Unified::enableAutoRange(bool enabled)
  _autoRangeEnabled = enabled;
    @brief  Sets the magnetometer's gain
void Adafruit_LSM303_Mag_Unified::setMagGain(lsm303MagGain gain)
  write8(LSM303_ADDRESS_MAG, LSM303_REGISTER_MAG_CRB_REG_M, (byte)gain);
  _magGain = gain;
  switch(gain)
    case LSM303_MAGGAIN_1_3:
      _lsm303Mag_Gauss_LSB_XY = 1100;
      _lsm303Mag_Gauss_LSB_Z  = 980;
      break;
    case LSM303_MAGGAIN_1_9:
      _lsm303Mag_Gauss_LSB_XY = 855;
      _lsm303Mag_Gauss_LSB_Z  = 760;
      break;
    case LSM303_MAGGAIN_2_5:
      _lsm303Mag_Gauss_LSB_XY = 670;
      _lsm303Mag_Gauss_LSB_Z  = 600;
      break;
    case LSM303_MAGGAIN_4_0:
      _lsm303Mag_Gauss_LSB_XY = 450;
      _lsm303Mag_Gauss_LSB_Z  = 400;
      break;
    case LSM303_MAGGAIN_4_7:
      _lsm303Mag_Gauss_LSB_XY = 400;
      _lsm303Mag_Gauss_LSB_Z  = 255;
      break;
    case LSM303_MAGGAIN_5_6:
      _lsm303Mag_Gauss_LSB_XY = 330;
      _lsm303Mag_Gauss_LSB_Z  = 295;
      break;
    case LSM303_MAGGAIN_8_1:
      _lsm303Mag_Gauss_LSB_XY = 230;
      _lsm303Mag_Gauss_LSB_Z  = 205;
      break;
void Adafruit_LSM303_Mag_Unified::getEvent(sensors_event_t *event) {
  bool readingValid = false;
  while(!readingValid)
    /* Read new data */
    read();
    /* Make sure the sensor isn't saturating if auto-ranging is enabled */
    if (!_autoRangeEnabled)
      readingValid = true;
    else
      Serial.print(_magData.x); Serial.print(" ");
      Serial.print(_magData.y); Serial.print(" ");
      Serial.print(_magData.z); Serial.println(" ");
      /* Check if the sensor is saturating or not */
      if ( (_magData.x >= 4090) | (_magData.x <= -4090) |
           (_magData.y >= 4090) | (_magData.y <= -4090) |
           (_magData.z >= 4090) | (_magData.z <= -4090) )
        /* Saturating .... increase the range if we can */
        switch(_magGain)
            setMagGain(LSM303_MAGGAIN_8_1);
            Serial.println("Changing range to +/- 8.1");
            break;
            setMagGain(LSM303_MAGGAIN_5_6);
            Serial.println("Changing range to +/- 5.6");
            break;
            setMagGain(LSM303_MAGGAIN_4_7);
            Serial.println("Changing range to +/- 4.7");
            break;
            setMagGain(LSM303_MAGGAIN_4_0);
            Serial.println("Changing range to +/- 4.0");
            break;
            setMagGain(LSM303_MAGGAIN_2_5);
            Serial.println("Changing range to +/- 2.5");
            break;
            setMagGain(LSM303_MAGGAIN_1_9);
            Serial.println("Changing range to +/- 1.9");
            break;
          default:
            break;
      else
        /* All values are withing range */
  event->type      = SENSOR_TYPE_MAGNETIC_FIELD;
  event->magnetic.x = _magData.x / _lsm303Mag_Gauss_LSB_XY * SENSORS_GAUSS_TO_MICROTESLA;
  event->magnetic.y = _magData.y / _lsm303Mag_Gauss_LSB_XY * SENSORS_GAUSS_TO_MICROTESLA;
  event->magnetic.z = _magData.z / _lsm303Mag_Gauss_LSB_Z * SENSORS_GAUSS_TO_MICROTESLA;
void Adafruit_LSM303_Mag_Unified::getSensor(sensor_t *sensor) {
  sensor->type        = SENSOR_TYPE_MAGNETIC_FIELD;
Hi there @peekay123 and @ScruffR!
I’m trying to use adafruit LSM303 sensor and push X,Y,Z variables to the cloud.
I’m using the code as below:
  sensor_t sensor;
  Serial.println("");
  delay(500);
void setup(void)
  Serial.begin(11520);
  sensors_event_t event; //calling class instance?
  Particle.variable("X", (int*)&event.acceleration.x,INT); //class.method.value?
  Particle.variable("Y", (int*)&event.acceleration.y, INT);
  Particle.variable("Z", (int*)&event.acceleration.z, INT);
  if(!accel.begin())
    while(1);
void loop(void)
  //Serial.print("X: ");
  Serial.println(event.acceleration.x); //Serial.print("  ");
  //Serial.print("Y: ");
  Serial.println(event.acceleration.y);// Serial.print("  ");
  //Serial.print("Z: ");
  Serial.println(event.acceleration.z); //Serial.print("  ");
  delay(1500);
It is returning random values:
Where have i gone wrong?
You are setting up a local (automatic) variable event in setup() and expose its fields, but once you leave setup() event will cease to exist and hence your Particle.variables() will refer to mem locations that no longer refer to the values you had located there before.
You need to declare event in global scope.
The names you use in your "readable" code are absolutely irrelevant for the actual machinge code.
Imagine you call the two event variables you are declaring once eventSetup and eventLoop (denoting their respective scope) and re-read your own code. This should make clear what I meant above.
Okay, i tried reading and implementing several ways for calling a member function at a global scope- nothing worked.
This is way over me compared to how little i know about C++
Have you also tried this way?
void setup(void)
  Serial.begin(115200);
  if(!accel.begin())
    while(1) Particle.process();  // ensure to still be able to OTA flash
  Particle.variable("X", (int*)&event.acceleration.x, INT);
void loop(void)
Note, the global sensors_event_t event;, the initialization of the sensor before first use of getEvent() and the addition of Particle.process() in case of failing to init.
No, acceleration is not a method, otherwise it would be called acceleration() (note the parentheses).
In fact acceleration is a member field of event and is a struct which in turn contains x, y and z as member fields again.
BTW: Even event is not neccessarily a class either, it could (more likely) be a struct too.
I have moved these posts over to this double post of yours, to keep things together rather than skattering them all over the place, and I've changed the category, since it's not a real Firmware question
Thanks for your response @ScruffR!
I tried your way and got these errors:
    accelerometer.cpp:7:21: error: 'sensors_event_t event' redeclared as different kind of symbol
In file included from ../communication/src/spark_descriptor.h:30:0,
                 from ../communication/src/spark_protocol_functions.h:13,
                 from ../wiring/inc/spark_wiring_version.h:27,
                 from ../wiring/inc/spark_wiring_system.h:27,
                 from ../wiring/inc/spark_wiring.h:45,
                 from ./inc/application.h:36,
                 from Adafruit_Sensor.h:23,
                 from accelerometer.cpp:1:
../communication/src/events.h:61:8: error: previous declaration of 'size_t event(uint8_t*, uint16_t, const char*, const char*, int, EventType::Enum)'
 size_t event(uint8_t buf[], uint16_t message_id, const char *event_name,
accelerometer.cpp: In function 'void displaySensorDetails()':
accelerometer.cpp:14:3: error: 'accel' was not declared in this scope
 //    extern int accel.getEvent;
accelerometer.cpp: In function 'void setup()':
accelerometer.cpp:32:3: error: 'accel' was not declared in this scope
accelerometer.cpp:33:38: error: request for member 'acceleration' in 'event', which is of non-class type 'size_t(uint8_t*, uint16_t, const char*, const char*, int, EventType::Enum) {aka unsigned int(unsigned char*, short unsigned int, const char*, const char*, int, EventType::Enum)}'
 void setup(void)
accelerometer.cpp: In function 'void loop()':
accelerometer.cpp:52:1: error: 'accel' was not declared in this scope
accelerometer.cpp:56:24: error: request for member 'acceleration' in 'event', which is of non-class type 'size_t(uint8_t*, uint16_t, const char*, const char*, int, EventType::Enum) {aka unsigned int(unsigned char*, short unsigned int, const char*, const char*, int, EventType::Enum)}'
accelerometer.cpp:58:24: error: request for member 'acceleration' in 'event', which is of non-class type 'size_t(uint8_t*, uint16_t, const char*, const char*, int, EventType::Enum) {aka unsigned int(unsigned char*, short unsigned int, const char*, const char*, int, EventType::Enum)}'
accelerometer.cpp:60:24: error: request for member 'acceleration' in 'event', which is of non-class type 'size_t(uint8_t*, uint16_t, const char*, const char*, int, EventType::Enum) {aka unsigned int(unsigned char*, short unsigned int, const char*, const char*, int, EventType::Enum)}'
I see, this is obviously a collision with some other global event variable introduced by other code not shown here.
Just rename all your instances of event into accEvent, then this should go away.
But by reading the error message, this should have been clear in a split second.
The other errors might be follow-on errors resulting from the previous.
It sure did make a lot errors go away.
This is the latest code:
    sensors_event_t accEvent;
  sensor_t sensor;
  Serial.println("");
  delay(500);
void setup(void)
extern int accel.getEvent(&accEvent);
  Particle.variable("X", (int*)accEvent.acceleration.x,INT);
  //Particle.variable("Y", (int*)event.acceleration.y, INT);
  //Particle.variable("Z", (int*)&event.acceleration.z, INT);
  if(!accel.begin())
void loop(void)
    //sensors_event_t event;
  Serial.println(accEvent.acceleration.x); //Serial.print("  ");
  Serial.println(accEvent.acceleration.y);// Serial.print("  ");
  Serial.println(accEvent.acceleration.z); //Serial.print("  ");
  delay(1500);
that said, i get these new errors complaining about data type for ‘accel’
accelerometer.cpp:12:3: error: 'accel' was not declared in this scope
accelerometer.cpp:30:17: error: expected initializer before '.' token
accelerometer.cpp:31:54: error: invalid cast from type 'float' to type 'int*'
 void setup(void)
accelerometer.cpp:35:7: error: 'accel' was not declared in this scope
accelerometer.cpp:50:17: error: expected initializer before '.' token
make[1]: *** [../build/target/user/platform-6accelerometer.o] Error 1
make: *** [user] Error 2
What are you doing? Each time I look at your code you seem to introduce new errors!
A few posts up, you had this line in
but now it's gone, causing the new errors.
Put this line back where it belongs.
And what should that be???
And why have you dropped the ampersand (&) from the Particle.variable() lines? They were there not just for decoration!
AH! lets say i went on a late night coding rampage! :smiley:Sorry, i was modifying the code quite often.
The code now compiles as following:
  sensor_t sensor;
  Serial.println("");
  delay(500);
void setup(void)
  Particle.variable("X", (int*)&accEvent.acceleration.x,INT);
  //Particle.variable("Y", (int*)&accEvent.acceleration.y, INT);
  //Particle.variable("Z", (int*)&accEvent.acceleration.z, INT);
  if(!accel.begin())
void loop(void)
  delay(500);
But when flashed to the board- LED blinks ‘fast’- green and cyan; and the board goes either dead(no led anymore) or goes solid cyan. i bring it to safe mode, repeat. this happens with or without ‘Particle.process()’
This should be 115200.
Since its solid off/cyan it seems that your code (or more likely the sensor lib) blocks to an extent that does even prevent the RGB LED update.
Does serial show any output?
Add some more print statements to locate the possition where the lockup happens. To make sure you capture everything do this
void serup()
  while(!Serial.read() < 0) Particle.process(); // wait for serial input  (keypress)
  Serial.println("Here we go, but how far?");
And please, do read my hints more carefully:
The sensor init has to happen before first use. I corrected that in my code but you kept it after accel.getEvent(&accEvent)!
It's rather irritating having to repeat myself!
