I am trying to get Adafruit’s IMU sensor to run on my SparkCore. Does anyone had any luck making it work?
@alexstyl, are you powering the board via the Vin pin of the Core? The board is actually designed for a 5V arduino. The library is straight forward to port from what I can see. Were you able to do the porting yourself?
I was wondering if anyone has done that before, since I am new to the SparkCore Community (let alone porting Android libraries to the Core).
I am currently try to port the lib myself, but my C/C++ isn’t that great, so this would take a while…
@alexstyl, I’ll port it for you tonight if I have the time and post it on my github repo. You can then copy it from there.
That’s great @peekay123 many thanks! I somehow managed to get it to compile for Spark, but didn’t have time to try it out just yet. I will later in the day
@alexstyl, let me know how it goes. No need to port if you did it!
@peekay123 Unfortunately even though it compiles it doesn't seem to send any data to the cloud and I don't know what is wrong. If you could port it for me, I would be grateful.
It fails to detect the sensor. I keep getting 'Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!'
EDIT: As it seems I did the wiring indeed wrong. Now it does detect the sensor, but it only sends to my local server readings three times, and then it stops
Orientation: 0.000000 -0.062500 3.562500
EDIT2: I added a delay of 1000ms and it sends new values properly. I found on some post somewhere that Spark.publish() allows up to 4 messages per second.
The ported library can be found here: GitHub - alexstyl/Adafruit-BNO055-SparkCore-port: A SparkCore port of Adafruit's library for the BNO055 sensor https://learn.adafruit.com/adafruit-bno055-absolute-orientation-sensor/
Since I am running the code on my local cloud, is it possible to avoid that since I need the sensor data with a really low delay?
Hi I am trying the same, how did you handle errors from Web-IDE for:
#include "Wire.h"
#include "imumaths.h"
What errors do you get?
You won’t need Wire.h.
You either need to add imumaths or replace the references to it with something available on the platform.
You need to add Adafruit_Sensors.h. If you use the one from the Web IDE repo, you’d need to change the includes to #include "Adafruit_Sensors/Adafruit_Sensors.h".
imumaths is required in Adafruit_BNO055.h to do vector calculations:
*line 234* imu::Vector<3> getVector ( adafruit_vector_type_t vector_type );
*line 244* imu::Quaternion getQuat ( void );
and imumaths itself requires 3 libraries:
#include "vector.h"
#include "matrix.h"
#include "quaternion.h"
Hello all,
I am too playing with this library, and have found that wire functions dont match and had to make changes to get it to compile. Once the changes were made the photon would only boot to safe-mode (red-blue). I am curious if the read8() functions that is being call is causing some the issues. I am willing to test any ideas on trying to get this working.
For my testing purposes I bought an Arduino pro mini to basically pump serial data to the particle, and then have the particle pump it out to where I need it to go from there. (Very very not ideal configuration.)
I will post more if I find something more.
Chrobi
So far I have changed three files. And the imumaths.h and supporting files are in the root directory as described in the files.
Here is the Adafruit_BNO055.cpp
This is a library for the BNO055 orientation sensor
Designed specifically to work with the Adafruit BNO055 Breakout.
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/products
These sensors use I2C to communicate, 2 pins are required to interface.
Adafruit invests time and resources providing this open source code,
please support Adafruit andopen-source hardware by purchasing products
from Adafruit!
Written by KTOWN for Adafruit Industries.
MIT license, all text above must be included in any redistribution
//#if ARDUINO >= 100
// #include "Arduino.h"
//#else
// #include "WProgram.h"
//#endif
#include "application.h"
#include <math.h>
#include <limits.h>
#include "Adafruit_BNO055.h"
CONSTRUCTOR
@brief Instantiates a new Adafruit_BNO055 class
Adafruit_BNO055::Adafruit_BNO055(int32_t sensorID, uint8_t address)
_sensorID = sensorID;
_address = address;
PUBLIC FUNCTIONS
@brief Sets up the HW
bool Adafruit_BNO055::begin(adafruit_bno055_opmode_t mode)
/* Enable I2C */
if ( !Wire.isEnabled() ) {
Wire.begin();
// Wire.begin();
/* Make sure we have the right device */
uint8_t id = read8(BNO055_CHIP_ID_ADDR);
if(id != BNO055_ID)
delay(1000); // hold on for boot
if(id != BNO055_ID) {
return false; // still not? ok bail
/* Switch to config mode (just in case since this is the default) */
setMode(OPERATION_MODE_CONFIG);
/* Reset */
write8(BNO055_SYS_TRIGGER_ADDR, 0x20);
while (read8(BNO055_CHIP_ID_ADDR) != BNO055_ID)
delay(10);
delay(50);
/* Set to normal power mode */
write8(BNO055_PWR_MODE_ADDR, POWER_MODE_NORMAL);
delay(10);
write8(BNO055_PAGE_ID_ADDR, 0);
/* Set the output units */
uint8_t unitsel = (0 << 7) | // Orientation = Android
(0 << 4) | // Temperature = Celsius
(0 << 2) | // Euler = Degrees
(1 << 1) | // Gyro = Rads
(0 << 0); // Accelerometer = m/s^2
write8(BNO055_UNIT_SEL_ADDR, unitsel);
write8(BNO055_SYS_TRIGGER_ADDR, 0x0);
delay(10);
/* Set the requested operating mode (see section 3.3) */
setMode(mode);
delay(20);
return true;
@brief Puts the chip in the specified operating mode
void Adafruit_BNO055::setMode(adafruit_bno055_opmode_t mode)
_mode = mode;
write8(BNO055_OPR_MODE_ADDR, _mode);
delay(30);
@brief Use the external 32.768KHz crystal
void Adafruit_BNO055::setExtCrystalUse(boolean usextal)
adafruit_bno055_opmode_t modeback = _mode;
delay(25);
if (usextal) {
write8(BNO055_SYS_TRIGGER_ADDR, 0x80);
} else {
write8(BNO055_SYS_TRIGGER_ADDR, 0x00);
delay(10);
setMode(modeback);
delay(20);
@brief Gets the latest system status info
void Adafruit_BNO055::getSystemStatus(uint8_t *system_status, uint8_t *self_test_result, uint8_t *system_error)
/* System Status (see section 4.3.58)
0 = Idle
1 = System Error
2 = Initializing Peripherals
3 = System Iniitalization
4 = Executing Self-Test
5 = Sensor fusio algorithm running
6 = System running without fusion algorithms */
if (system_status != 0)
*system_status = read8(BNO055_SYS_STAT_ADDR);
/* Self Test Results (see section )
1 = test passed, 0 = test failed
Bit 0 = Accelerometer self test
Bit 1 = Magnetometer self test
Bit 2 = Gyroscope self test
Bit 3 = MCU self test
0x0F = all good! */
if (self_test_result != 0)
*self_test_result = read8(BNO055_SELFTEST_RESULT_ADDR);
/* System Error (see section 4.3.59)
0 = No error
1 = Peripheral initialization error
2 = System initialization error
3 = Self test result failed
4 = Register map value out of range
5 = Register map address out of range
6 = Register map write error
7 = BNO low power mode not available for selected operat ion mode
8 = Accelerometer power mode not available
9 = Fusion algorithm configuration error
A = Sensor configuration error */
if (system_error != 0)
*system_error = read8(BNO055_SYS_ERR_ADDR);
delay(200);
@brief Gets the chip revision numbers
void Adafruit_BNO055::getRevInfo(adafruit_bno055_rev_info_t* info)
uint8_t a, b;
memset(info, 0, sizeof(adafruit_bno055_rev_info_t));
/* Check the accelerometer revision */
info->accel_rev = read8(BNO055_ACCEL_REV_ID_ADDR);
/* Check the magnetometer revision */
info->mag_rev = read8(BNO055_MAG_REV_ID_ADDR);
/* Check the gyroscope revision */
info->gyro_rev = read8(BNO055_GYRO_REV_ID_ADDR);
/* Check the SW revision */
info->bl_rev = read8(BNO055_BL_REV_ID_ADDR);
a = read8(BNO055_SW_REV_ID_LSB_ADDR);
b = read8(BNO055_SW_REV_ID_MSB_ADDR);
info->sw_rev = (((uint16_t)b) << 8) | ((uint16_t)a);
@brief Gets current calibration state. Each value should be a uint8_t
pointer and it will be set to 0 if not calibrated and 3 if
fully calibrated.
void Adafruit_BNO055::getCalibration(uint8_t* sys, uint8_t* gyro, uint8_t* accel, uint8_t* mag) {
uint8_t calData = read8(BNO055_CALIB_STAT_ADDR);
if (sys != NULL) {
*sys = (calData >> 6) & 0x03;
if (gyro != NULL) {
*gyro = (calData >> 4) & 0x03;
if (accel != NULL) {
*accel = (calData >> 2) & 0x03;
if (mag != NULL) {
*mag = calData & 0x03;
@brief Gets the temperature in degrees celsius
int8_t Adafruit_BNO055::getTemp(void)
int8_t temp = (int8_t)(read8(BNO055_TEMP_ADDR));
return temp;
@brief Gets a vector reading from the specified source
imu::Vector<3> Adafruit_BNO055::getVector(adafruit_vector_type_t vector_type)
imu::Vector<3> xyz;
uint8_t buffer[6];
memset (buffer, 0, 6);
int16_t x, y, z;
x = y = z = 0;
/* Read vector data (6 bytes) */
readLen((adafruit_bno055_reg_t)vector_type, buffer, 6);
x = ((int16_t)buffer[0]) | (((int16_t)buffer[1]) << 8);
y = ((int16_t)buffer[2]) | (((int16_t)buffer[3]) << 8);
z = ((int16_t)buffer[4]) | (((int16_t)buffer[5]) << 8);
/* Convert the value to an appropriate range (section 3.6.4) */
/* and assign the value to the Vector type */
switch(vector_type)
case VECTOR_MAGNETOMETER:
/* 1uT = 16 LSB */
xyz[0] = ((double)x)/16.0;
xyz[1] = ((double)y)/16.0;
xyz[2] = ((double)z)/16.0;
break;
case VECTOR_GYROSCOPE:
/* 1rps = 900 LSB */
xyz[0] = ((double)x)/900.0;
xyz[1] = ((double)y)/900.0;
xyz[2] = ((double)z)/900.0;
break;
case VECTOR_EULER:
/* 1 degree = 16 LSB */
break;
case VECTOR_ACCELEROMETER:
case VECTOR_LINEARACCEL:
case VECTOR_GRAVITY:
/* 1m/s^2 = 100 LSB */
xyz[0] = ((double)x)/100.0;
xyz[1] = ((double)y)/100.0;
xyz[2] = ((double)z)/100.0;
break;
return xyz;
@brief Gets a quaternion reading from the specified source
imu::Quaternion Adafruit_BNO055::getQuat(void)
uint8_t buffer[8];
memset (buffer, 0, 8);
int16_t x, y, z, w;
x = y = z = w = 0;
/* Read quat data (8 bytes) */
readLen(BNO055_QUATERNION_DATA_W_LSB_ADDR, buffer, 8);
w = (((uint16_t)buffer[1]) << 8) | ((uint16_t)buffer[0]);
x = (((uint16_t)buffer[3]) << 8) | ((uint16_t)buffer[2]);
y = (((uint16_t)buffer[5]) << 8) | ((uint16_t)buffer[4]);
z = (((uint16_t)buffer[7]) << 8) | ((uint16_t)buffer[6]);
/* Assign to Quaternion */
/* See http://ae-bst.resource.bosch.com/media/products/dokumente/bno055/BST_BNO055_DS000_12~1.pdf
3.6.5.5 Orientation (Quaternion) */
const double scale = (1.0 / (1<<14));
imu::Quaternion quat(scale * w, scale * x, scale * y, scale * z);
return quat;
@brief Provides the sensor_t data for this sensor
void Adafruit_BNO055::getSensor(sensor_t *sensor)
/* Clear the sensor_t object */
memset(sensor, 0, sizeof(sensor_t));
/* Insert the sensor name in the fixed length char array */
strncpy (sensor->name, "BNO055", sizeof(sensor->name) - 1);
sensor->name[sizeof(sensor->name)- 1] = 0;
sensor->version = 1;
sensor->sensor_id = _sensorID;
sensor->type = SENSOR_TYPE_ORIENTATION;
sensor->min_delay = 0;
sensor->max_value = 0.0F;
sensor->min_value = 0.0F;
sensor->resolution = 0.01F;
@brief Reads the sensor and returns the data as a sensors_event_t
bool Adafruit_BNO055::getEvent(sensors_event_t *event)
/* Clear the event */
memset(event, 0, sizeof(sensors_event_t));
event->version = sizeof(sensors_event_t);
event->sensor_id = _sensorID;
event->type = SENSOR_TYPE_ORIENTATION;
event->timestamp = millis();
/* Get a Euler angle sample for orientation */
imu::Vector<3> euler = getVector(Adafruit_BNO055::VECTOR_EULER);
event->orientation.x = euler.x();
event->orientation.y = euler.y();
event->orientation.z = euler.z();
return true;
@brief Reads the sensor's offset registers into a byte array
bool Adafruit_BNO055::getSensorOffsets(uint8_t* calibData)
if (isFullyCalibrated())
adafruit_bno055_opmode_t lastMode = _mode;
readLen(ACCEL_OFFSET_X_LSB_ADDR, calibData, NUM_BNO055_OFFSET_REGISTERS);
setMode(lastMode);
return true;
return false;
@brief Reads the sensor's offset registers into an offset struct
bool Adafruit_BNO055::getSensorOffsets(adafruit_bno055_offsets_t &offsets_type)
delay(25);
offsets_type.accel_offset_x = (read8(ACCEL_OFFSET_X_MSB_ADDR) << 8) | (read8(ACCEL_OFFSET_X_LSB_ADDR));
offsets_type.accel_offset_y = (read8(ACCEL_OFFSET_Y_MSB_ADDR) << 8) | (read8(ACCEL_OFFSET_Y_LSB_ADDR));
offsets_type.accel_offset_z = (read8(ACCEL_OFFSET_Z_MSB_ADDR) << 8) | (read8(ACCEL_OFFSET_Z_LSB_ADDR));
offsets_type.gyro_offset_x = (read8(GYRO_OFFSET_X_MSB_ADDR) << 8) | (read8(GYRO_OFFSET_X_LSB_ADDR));
offsets_type.gyro_offset_y = (read8(GYRO_OFFSET_Y_MSB_ADDR) << 8) | (read8(GYRO_OFFSET_Y_LSB_ADDR));
offsets_type.gyro_offset_z = (read8(GYRO_OFFSET_Z_MSB_ADDR) << 8) | (read8(GYRO_OFFSET_Z_LSB_ADDR));
offsets_type.mag_offset_x = (read8(MAG_OFFSET_X_MSB_ADDR) << 8) | (read8(MAG_OFFSET_X_LSB_ADDR));
offsets_type.mag_offset_y = (read8(MAG_OFFSET_Y_MSB_ADDR) << 8) | (read8(MAG_OFFSET_Y_LSB_ADDR));
offsets_type.mag_offset_z = (read8(MAG_OFFSET_Z_MSB_ADDR) << 8) | (read8(MAG_OFFSET_Z_LSB_ADDR));
offsets_type.accel_radius = (read8(ACCEL_RADIUS_MSB_ADDR) << 8) | (read8(ACCEL_RADIUS_LSB_ADDR));
offsets_type.mag_radius = (read8(MAG_RADIUS_MSB_ADDR) << 8) | (read8(MAG_RADIUS_LSB_ADDR));
setMode(lastMode);
return true;
return false;
@brief Writes an array of calibration values to the sensor's offset registers
void Adafruit_BNO055::setSensorOffsets(const uint8_t* calibData)
delay(25);
/* A writeLen() would make this much cleaner */
write8(ACCEL_OFFSET_X_LSB_ADDR, calibData[0]);
write8(ACCEL_OFFSET_X_MSB_ADDR, calibData[1]);
write8(ACCEL_OFFSET_Y_LSB_ADDR, calibData[2]);
write8(ACCEL_OFFSET_Y_MSB_ADDR, calibData[3]);
write8(ACCEL_OFFSET_Z_LSB_ADDR, calibData[4]);
write8(ACCEL_OFFSET_Z_MSB_ADDR, calibData[5]);
write8(GYRO_OFFSET_X_LSB_ADDR, calibData[6]);
write8(GYRO_OFFSET_X_MSB_ADDR, calibData[7]);
write8(GYRO_OFFSET_Y_LSB_ADDR, calibData[8]);
write8(GYRO_OFFSET_Y_MSB_ADDR, calibData[9]);
write8(GYRO_OFFSET_Z_LSB_ADDR, calibData[10]);
write8(GYRO_OFFSET_Z_MSB_ADDR, calibData[11]);
write8(MAG_OFFSET_X_LSB_ADDR, calibData[12]);
write8(MAG_OFFSET_X_MSB_ADDR, calibData[13]);
write8(MAG_OFFSET_Y_LSB_ADDR, calibData[14]);
write8(MAG_OFFSET_Y_MSB_ADDR, calibData[15]);
write8(MAG_OFFSET_Z_LSB_ADDR, calibData[16]);
write8(MAG_OFFSET_Z_MSB_ADDR, calibData[17]);
write8(ACCEL_RADIUS_LSB_ADDR, calibData[18]);
write8(ACCEL_RADIUS_MSB_ADDR, calibData[19]);
write8(MAG_RADIUS_LSB_ADDR, calibData[20]);
write8(MAG_RADIUS_MSB_ADDR, calibData[21]);
setMode(lastMode);
@brief Writes to the sensor's offset registers from an offset struct
void Adafruit_BNO055::setSensorOffsets(const adafruit_bno055_offsets_t &offsets_type)
delay(25);
write8(ACCEL_OFFSET_X_LSB_ADDR, (offsets_type.accel_offset_x) & 0x0FF);
write8(ACCEL_OFFSET_X_MSB_ADDR, (offsets_type.accel_offset_x >> 8) & 0x0FF);
write8(ACCEL_OFFSET_Y_LSB_ADDR, (offsets_type.accel_offset_y) & 0x0FF);
write8(ACCEL_OFFSET_Y_MSB_ADDR, (offsets_type.accel_offset_y >> 8) & 0x0FF);
write8(ACCEL_OFFSET_Z_LSB_ADDR, (offsets_type.accel_offset_z) & 0x0FF);
write8(ACCEL_OFFSET_Z_MSB_ADDR, (offsets_type.accel_offset_z >> 8) & 0x0FF);
write8(GYRO_OFFSET_X_LSB_ADDR, (offsets_type.gyro_offset_x) & 0x0FF);
write8(GYRO_OFFSET_X_MSB_ADDR, (offsets_type.gyro_offset_x >> 8) & 0x0FF);
write8(GYRO_OFFSET_Y_LSB_ADDR, (offsets_type.gyro_offset_y) & 0x0FF);
write8(GYRO_OFFSET_Y_MSB_ADDR, (offsets_type.gyro_offset_y >> 8) & 0x0FF);
write8(GYRO_OFFSET_Z_LSB_ADDR, (offsets_type.gyro_offset_z) & 0x0FF);
write8(GYRO_OFFSET_Z_MSB_ADDR, (offsets_type.gyro_offset_z >> 8) & 0x0FF);
write8(MAG_OFFSET_X_LSB_ADDR, (offsets_type.mag_offset_x) & 0x0FF);
write8(MAG_OFFSET_X_MSB_ADDR, (offsets_type.mag_offset_x >> 8) & 0x0FF);
write8(MAG_OFFSET_Y_LSB_ADDR, (offsets_type.mag_offset_y) & 0x0FF);
write8(MAG_OFFSET_Y_MSB_ADDR, (offsets_type.mag_offset_y >> 8) & 0x0FF);
write8(MAG_OFFSET_Z_LSB_ADDR, (offsets_type.mag_offset_z) & 0x0FF);
write8(MAG_OFFSET_Z_MSB_ADDR, (offsets_type.mag_offset_z >> 8) & 0x0FF);
write8(ACCEL_RADIUS_LSB_ADDR, (offsets_type.accel_radius) & 0x0FF);
write8(ACCEL_RADIUS_MSB_ADDR, (offsets_type.accel_radius >> 8) & 0x0FF);
write8(MAG_RADIUS_LSB_ADDR, (offsets_type.mag_radius) & 0x0FF);
write8(MAG_RADIUS_MSB_ADDR, (offsets_type.mag_radius >> 8) & 0x0FF);
setMode(lastMode);
bool Adafruit_BNO055::isFullyCalibrated(void)
uint8_t system, gyro, accel, mag;
getCalibration(&system, &gyro, &accel, &mag);
if (system < 3 || gyro < 3 || accel < 3 || mag < 3)
return false;
return true;
PRIVATE FUNCTIONS
@brief Writes an 8 bit value over I2C
bool Adafruit_BNO055::write8(adafruit_bno055_reg_t reg, byte value)
Wire.beginTransmission(_address);
#if ARDUINO >= 100
Wire.write((uint8_t)reg);
Wire.write((uint8_t)value);
#else
Wire.write(reg);
Wire.write(value);
#endif
Wire.endTransmission();
/* ToDo: Check for error! */
return true;
@brief Reads an 8 bit value over I2C
byte Adafruit_BNO055::read8(adafruit_bno055_reg_t reg )
byte value = 0;
#if ARDUINO >= 100
#else
Wire.write(reg);
#endif
Wire.requestFrom(_address, (byte)1);
#if ARDUINO >= 100
value = Wire.read();
#else
#endif
return value;
@brief Reads the specified number of bytes over I2C
bool Adafruit_BNO055::readLen(adafruit_bno055_reg_t reg, byte * buffer, uint8_t len)
#if ARDUINO >= 100
#else
Wire.write(reg);
#endif
Wire.requestFrom(_address, (byte)len);
for (uint8_t i = 0; i < len; i++)
#if ARDUINO >= 100
buffer[i] = Wire.read();
#else
#endif
/* ToDo: Check for errors! */
return true;
Here is the Adafruit_BNO055.h
from Adafruit!
#ifndef __ADAFRUIT_BNO055_H__
#define __ADAFRUIT_BNO055_H__
//#if (ARDUINO >= 100)
//#else
//#endif
//#ifdef __AVR_ATtiny85__
//#include <TinyWireM.h>
// #define Wire TinyWireM
//#else
// #include <Wire.h>
//#endif
#include <Adafruit_Sensor.h>
#include <imumaths.h>
#define BNO055_ADDRESS_A (0x28)
#define BNO055_ADDRESS_B (0x29)
#define BNO055_ID (0xA0)
#define NUM_BNO055_OFFSET_REGISTERS (22)
typedef struct
uint16_t accel_offset_x;
uint16_t accel_offset_y;
uint16_t accel_offset_z;
uint16_t gyro_offset_x;
uint16_t gyro_offset_y;
uint16_t gyro_offset_z;
uint16_t mag_offset_x;
uint16_t mag_offset_y;
uint16_t mag_offset_z;
uint16_t accel_radius;
uint16_t mag_radius;
} adafruit_bno055_offsets_t;
class Adafruit_BNO055 : public Adafruit_Sensor
public:
typedef enum
/* Page id register definition */
BNO055_PAGE_ID_ADDR = 0X07,
/* PAGE0 REGISTER DEFINITION START*/
BNO055_CHIP_ID_ADDR = 0x00,
BNO055_ACCEL_REV_ID_ADDR = 0x01,
BNO055_MAG_REV_ID_ADDR = 0x02,
BNO055_GYRO_REV_ID_ADDR = 0x03,
BNO055_SW_REV_ID_LSB_ADDR = 0x04,
BNO055_SW_REV_ID_MSB_ADDR = 0x05,
BNO055_BL_REV_ID_ADDR = 0X06,
/* Accel data register */
BNO055_ACCEL_DATA_X_LSB_ADDR = 0X08,
BNO055_ACCEL_DATA_X_MSB_ADDR = 0X09,
BNO055_ACCEL_DATA_Y_LSB_ADDR = 0X0A,
BNO055_ACCEL_DATA_Y_MSB_ADDR = 0X0B,
BNO055_ACCEL_DATA_Z_LSB_ADDR = 0X0C,
BNO055_ACCEL_DATA_Z_MSB_ADDR = 0X0D,
/* Mag data register */
BNO055_MAG_DATA_X_LSB_ADDR = 0X0E,
BNO055_MAG_DATA_X_MSB_ADDR = 0X0F,
BNO055_MAG_DATA_Y_LSB_ADDR = 0X10,
BNO055_MAG_DATA_Y_MSB_ADDR = 0X11,
BNO055_MAG_DATA_Z_LSB_ADDR = 0X12,
BNO055_MAG_DATA_Z_MSB_ADDR = 0X13,
/* Gyro data registers */
BNO055_GYRO_DATA_X_LSB_ADDR = 0X14,
BNO055_GYRO_DATA_X_MSB_ADDR = 0X15,
BNO055_GYRO_DATA_Y_LSB_ADDR = 0X16,
BNO055_GYRO_DATA_Y_MSB_ADDR = 0X17,
BNO055_GYRO_DATA_Z_LSB_ADDR = 0X18,
BNO055_GYRO_DATA_Z_MSB_ADDR = 0X19,
/* Euler data registers */
BNO055_EULER_H_LSB_ADDR = 0X1A,
BNO055_EULER_H_MSB_ADDR = 0X1B,
BNO055_EULER_R_LSB_ADDR = 0X1C,
BNO055_EULER_R_MSB_ADDR = 0X1D,
BNO055_EULER_P_LSB_ADDR = 0X1E,
BNO055_EULER_P_MSB_ADDR = 0X1F,
/* Quaternion data registers */
BNO055_QUATERNION_DATA_W_LSB_ADDR = 0X20,
BNO055_QUATERNION_DATA_W_MSB_ADDR = 0X21,
BNO055_QUATERNION_DATA_X_LSB_ADDR = 0X22,
BNO055_QUATERNION_DATA_X_MSB_ADDR = 0X23,
BNO055_QUATERNION_DATA_Y_LSB_ADDR = 0X24,
BNO055_QUATERNION_DATA_Y_MSB_ADDR = 0X25,
BNO055_QUATERNION_DATA_Z_LSB_ADDR = 0X26,
BNO055_QUATERNION_DATA_Z_MSB_ADDR = 0X27,
/* Linear acceleration data registers */
BNO055_LINEAR_ACCEL_DATA_X_LSB_ADDR = 0X28,
BNO055_LINEAR_ACCEL_DATA_X_MSB_ADDR = 0X29,
BNO055_LINEAR_ACCEL_DATA_Y_LSB_ADDR = 0X2A,
BNO055_LINEAR_ACCEL_DATA_Y_MSB_ADDR = 0X2B,
BNO055_LINEAR_ACCEL_DATA_Z_LSB_ADDR = 0X2C,
BNO055_LINEAR_ACCEL_DATA_Z_MSB_ADDR = 0X2D,
/* Gravity data registers */
BNO055_GRAVITY_DATA_X_LSB_ADDR = 0X2E,
BNO055_GRAVITY_DATA_X_MSB_ADDR = 0X2F,
BNO055_GRAVITY_DATA_Y_LSB_ADDR = 0X30,
BNO055_GRAVITY_DATA_Y_MSB_ADDR = 0X31,
BNO055_GRAVITY_DATA_Z_LSB_ADDR = 0X32,
BNO055_GRAVITY_DATA_Z_MSB_ADDR = 0X33,
/* Temperature data register */
BNO055_TEMP_ADDR = 0X34,
/* Status registers */
BNO055_CALIB_STAT_ADDR = 0X35,
BNO055_SELFTEST_RESULT_ADDR = 0X36,
BNO055_INTR_STAT_ADDR = 0X37,
BNO055_SYS_CLK_STAT_ADDR = 0X38,
BNO055_SYS_STAT_ADDR = 0X39,
BNO055_SYS_ERR_ADDR = 0X3A,
/* Unit selection register */
BNO055_UNIT_SEL_ADDR = 0X3B,
BNO055_DATA_SELECT_ADDR = 0X3C,
/* Mode registers */
BNO055_OPR_MODE_ADDR = 0X3D,
BNO055_PWR_MODE_ADDR = 0X3E,
BNO055_SYS_TRIGGER_ADDR = 0X3F,
BNO055_TEMP_SOURCE_ADDR = 0X40,
/* Axis remap registers */
BNO055_AXIS_MAP_CONFIG_ADDR = 0X41,
BNO055_AXIS_MAP_SIGN_ADDR = 0X42,
/* SIC registers */
BNO055_SIC_MATRIX_0_LSB_ADDR = 0X43,
BNO055_SIC_MATRIX_0_MSB_ADDR = 0X44,
BNO055_SIC_MATRIX_1_LSB_ADDR = 0X45,
BNO055_SIC_MATRIX_1_MSB_ADDR = 0X46,
BNO055_SIC_MATRIX_2_LSB_ADDR = 0X47,
BNO055_SIC_MATRIX_2_MSB_ADDR = 0X48,
BNO055_SIC_MATRIX_3_LSB_ADDR = 0X49,
BNO055_SIC_MATRIX_3_MSB_ADDR = 0X4A,
BNO055_SIC_MATRIX_4_LSB_ADDR = 0X4B,
BNO055_SIC_MATRIX_4_MSB_ADDR = 0X4C,
BNO055_SIC_MATRIX_5_LSB_ADDR = 0X4D,
BNO055_SIC_MATRIX_5_MSB_ADDR = 0X4E,
BNO055_SIC_MATRIX_6_LSB_ADDR = 0X4F,
BNO055_SIC_MATRIX_6_MSB_ADDR = 0X50,
BNO055_SIC_MATRIX_7_LSB_ADDR = 0X51,
BNO055_SIC_MATRIX_7_MSB_ADDR = 0X52,
BNO055_SIC_MATRIX_8_LSB_ADDR = 0X53,
BNO055_SIC_MATRIX_8_MSB_ADDR = 0X54,
/* Accelerometer Offset registers */
ACCEL_OFFSET_X_LSB_ADDR = 0X55,
ACCEL_OFFSET_X_MSB_ADDR = 0X56,
ACCEL_OFFSET_Y_LSB_ADDR = 0X57,
ACCEL_OFFSET_Y_MSB_ADDR = 0X58,
ACCEL_OFFSET_Z_LSB_ADDR = 0X59,
ACCEL_OFFSET_Z_MSB_ADDR = 0X5A,
/* Magnetometer Offset registers */
MAG_OFFSET_X_LSB_ADDR = 0X5B,
MAG_OFFSET_X_MSB_ADDR = 0X5C,
MAG_OFFSET_Y_LSB_ADDR = 0X5D,
MAG_OFFSET_Y_MSB_ADDR = 0X5E,
MAG_OFFSET_Z_LSB_ADDR = 0X5F,
MAG_OFFSET_Z_MSB_ADDR = 0X60,
/* Gyroscope Offset register s*/
GYRO_OFFSET_X_LSB_ADDR = 0X61,
GYRO_OFFSET_X_MSB_ADDR = 0X62,
GYRO_OFFSET_Y_LSB_ADDR = 0X63,
GYRO_OFFSET_Y_MSB_ADDR = 0X64,
GYRO_OFFSET_Z_LSB_ADDR = 0X65,
GYRO_OFFSET_Z_MSB_ADDR = 0X66,
/* Radius registers */
ACCEL_RADIUS_LSB_ADDR = 0X67,
ACCEL_RADIUS_MSB_ADDR = 0X68,
MAG_RADIUS_LSB_ADDR = 0X69,
MAG_RADIUS_MSB_ADDR = 0X6A
} adafruit_bno055_reg_t;
typedef enum
POWER_MODE_NORMAL = 0X00,
POWER_MODE_LOWPOWER = 0X01,
POWER_MODE_SUSPEND = 0X02
} adafruit_bno055_powermode_t;
typedef enum
/* Operation mode settings*/
OPERATION_MODE_CONFIG = 0X00,
OPERATION_MODE_ACCONLY = 0X01,
OPERATION_MODE_MAGONLY = 0X02,
OPERATION_MODE_GYRONLY = 0X03,
OPERATION_MODE_ACCMAG = 0X04,
OPERATION_MODE_ACCGYRO = 0X05,
OPERATION_MODE_MAGGYRO = 0X06,
OPERATION_MODE_AMG = 0X07,
OPERATION_MODE_IMUPLUS = 0X08,
OPERATION_MODE_COMPASS = 0X09,
OPERATION_MODE_M4G = 0X0A,
OPERATION_MODE_NDOF_FMC_OFF = 0X0B,
OPERATION_MODE_NDOF = 0X0C
} adafruit_bno055_opmode_t;
typedef struct
uint8_t accel_rev;
uint8_t mag_rev;
uint8_t gyro_rev;
uint16_t sw_rev;
uint8_t bl_rev;
} adafruit_bno055_rev_info_t;
typedef enum
VECTOR_ACCELEROMETER = BNO055_ACCEL_DATA_X_LSB_ADDR,
VECTOR_MAGNETOMETER = BNO055_MAG_DATA_X_LSB_ADDR,
VECTOR_GYROSCOPE = BNO055_GYRO_DATA_X_LSB_ADDR,
VECTOR_EULER = BNO055_EULER_H_LSB_ADDR,
VECTOR_LINEARACCEL = BNO055_LINEAR_ACCEL_DATA_X_LSB_ADDR,
VECTOR_GRAVITY = BNO055_GRAVITY_DATA_X_LSB_ADDR
} adafruit_vector_type_t;
Adafruit_BNO055 ( int32_t sensorID = -1, uint8_t address = BNO055_ADDRESS_A );
bool begin ( adafruit_bno055_opmode_t mode = OPERATION_MODE_NDOF );
void setMode ( adafruit_bno055_opmode_t mode );
void getRevInfo ( adafruit_bno055_rev_info_t* );
void displayRevInfo ( void );
void setExtCrystalUse ( boolean usextal );
void getSystemStatus ( uint8_t *system_status,
uint8_t *system_error);
void displaySystemStatus ( void );
void getCalibration ( uint8_t* system, uint8_t* gyro, uint8_t* accel, uint8_t* mag);
int8_t getTemp ( void );
/* Adafruit_Sensor implementation */
bool getEvent ( sensors_event_t* );
void getSensor ( sensor_t* );
/* Functions to deal with raw calibration data */
bool getSensorOffsets(uint8_t* calibData);
bool getSensorOffsets(adafruit_bno055_offsets_t &offsets_type);
void setSensorOffsets(const uint8_t* calibData);
void setSensorOffsets(const adafruit_bno055_offsets_t &offsets_type);
bool isFullyCalibrated(void);
private:
byte read8 ( adafruit_bno055_reg_t );
bool readLen ( adafruit_bno055_reg_t, byte* buffer, uint8_t len );
bool write8 ( adafruit_bno055_reg_t, byte value );
uint8_t _address;
int32_t _sensorID;
adafruit_bno055_opmode_t _mode;
#endif
And here is the Adafruit_Sensor.cpp:
* Copyright (C) 2008 The Android Open Source Project
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software< /span>
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
/* Update by K. Townsend (Adafruit Industries) for lighter typedefs, and
* extended sensor support to include color, voltage and current */
#ifndef _ADAFRUIT_SENSOR_H
#define _ADAFRUIT_SENSOR_H
// #include "Print.h"
//#else
//#endif
/* Intentionally modeled after sensors.h in the Android API:
* https://github.com/android/platform_hardware_libhardware/blob/master/include/hardware/sensors.h */
/* Constants */
#define SENSORS_GRAVITY_EARTH (9.80665F) /**< Earth's gravity in m/s^2 */
#define SENSORS_GRAVITY_MOON (1.6F) /**< The moon's gravity in m/s^2 */
#define SENSORS_GRAVITY_SUN (275.0F) /**< The sun's gravity in m/s^2 */
#define SENSORS_GRAVITY_STANDARD (SENSORS_GRAVITY_EARTH)
#define SENSORS_MAGFIELD_EARTH_MAX (60.0F) /**< Maximum magnetic field on Earth's surface */
#define SENSORS_MAGFIELD_EARTH_MIN (30.0F) /**< Minimum magnetic field on Earth's surface */
#define SENSORS_PRESSURE_SEALEVELHPA (1013.25F) /**< Average sea level pressure is 1013.25 hPa */
#define SENSORS_DPS_TO_RADS (0.017453293F) /**< Degrees/s to rad/s multiplier */
#define SENSORS_GAUSS_TO_MICROTESLA (100) /**< Gauss to micro-Tesla multiplier */
/** Sensor types */
typedef enum
SENSOR_TYPE_ACCELEROMETER = (1), /**< Gravity + linear acceleration */
SENSOR_TYPE_MAGNETIC_FIELD = (2),
SENSOR_TYPE_ORIENTATION = (3),
SENSOR_TYPE_GYROSCOPE = (4),
SENSOR_TYPE_LIGHT = (5),
SENSOR_TYPE_PRESSURE = (6),
SENSOR_TYPE_PROXIMITY = (8),
SENSOR_TYPE_GRAVITY = (9),
SENSOR_TYPE_LINEAR_ACCELERATION = (10), /**< Acceleration not including gravity */
SENSOR_TYPE_ROTATION_VECTOR = (11),
SENSOR_TYPE_RELATIVE_HUMIDITY = (12),
SENSOR_TYPE_AMBIENT_TEMPERATURE = (13),
SENSOR_TYPE_VOLTAGE = (15),
SENSOR_TYPE_CURRENT = (16),
SENSOR_TYPE_COLOR = (17)
} sensors_type_t;
/** struct sensors_vec_s is used to return a vector in a common format. */
typedef struct {
union {
float v[3];
struct {
float x;
float y;
float z;
/* Orientation sensors */
struct {
float roll; /**< Rotation around the longitudinal axis (the plane body, 'X axis'). Roll is positive and increasing when moving downward. -90�<=roll<=90� */
float pitch; /**< Rotation around the lateral axis (the wing span, 'Y axis'). Pitch is positive and increasing when moving upwards. -180�<=pitch<=180�) */
float heading; /**< Angle between the longitudinal axis (the plane body) and magnetic north, measured clockwise when viewing from the top of the device. 0-359� */
int8_t status;
uint8_t reserved[3];
} sensors_vec_t;
/** struct sensors_color_s is used to return color data in a common format. */
typedef struct {
union {
float c[3];
/* RGB color space */
struct {
float r; /**< Red component */
float g; /**< Green component */
float b; /**< Blue component */
uint32_t rgba; /**< 24-bit RGBA value */
} sensors_color_t;
/* Sensor event (36 bytes) */
/** struct sensor_event_s is used to provide a single sensor event in a common format. */
typedef struct
int32_t version; /**< must be sizeof(struct sensors_event_t) */
int32_t sensor_id; /**< unique sensor identifier */
int32_t type; /**< sensor type */
int32_t reserved0; /**< reserved */
int32_t timestamp; /**< time is in milliseconds */
union
float data[4];
sensors_vec_t acceleration; /**< acceleration values are in meter per second per second (m/s^2) */
sensors_vec_t magnetic; /**< magnetic vector values are in micro-Tesla (uT) */
sensors_vec_t orientation; /**< orientation values are in degrees */
sensors_vec_t gyro; /**< gyroscope values are in rad/s */
float temperature; /**< temperature is in degrees centigrade (Celsius) */
float distance; /**< distance in centimeters */
float light; /**< light in SI lux units */
float pressure; /**< pressure in hectopascal (hPa) */
float relative_humidity; /**< relative humidity in percent */
float current; /**< current in milliamps (mA) */
float voltage; /**< voltage in volts (V) */
sensors_color_t color; /**< color in RGB component values */
} sensors_event_t;
/* Sensor details (40 bytes) */
/** struct sensor_s is used to describe basic information about a specific sensor. */
typedef struct
char name[12]; /**< sensor name */
int32_t version; /**< version of the hardware + driver */
int32_t type; /**< this sensor's type (ex. SENSOR_TYPE_LIGHT) */
float max_value; /**< maximum value of this sensor's value in SI units */
float min_value; /**< minimum value of this sensor's value in SI units */
float resolution; /**< smallest difference between two values reported by this sensor */
int32_t min_delay; /**< min delay in microseconds between events. zero = not a constant rate */
} sensor_t;
class Adafruit_Sensor {
public:
// Constructor(s)
Adafruit_Sensor() {}
virtual ~Adafruit_Sensor() {}
// These must be defined by the subclass
virtual void enableAutoRange(bool enabled) {};
virtual bool getEvent(sensors_event_t*) = 0;
virtual void getSensor(sensor_t*) = 0;
private:
bool _autoRange;
#endif
Are you sure your devices sys firmware version matches the version of your application firmware?
Try flashing a simple blinky with target 0.4.7.
Let the device update if needed (might take a while).
Then try reflashing your project.
Thank you for the suggestion, the blink led code that triggers D7 works just fine. I have flashed the latest firmware from the git hub spark/firmware with the following instructions:
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.4.7-photon.bin
dfu-util -d 2b04:d006 -a 0 -s 0x8060000:leave -D system-part2-0.4.7-photon.bin
And still have same redblue combo for the code. and as soon as I reflash with led d7 blinks…
Thank you for your time and efforts on this Scruffr
Chrobi
very nice, this works for my Particle Core now. I can see data from spark.publish() in particle dashboard. But from time to time the core goes offline (repeating every 10-15 seconds) and come back online some seconds later. I tried to wire the sensore to vin and 3.3v and set the spark.publish() delay from 500 to 1000ms - no difference. Any suggestions why this happens? Also I dont get the serial prints (115200 baud) in serial monitor. Here the .ino file im using:
#include "Adafruit_Sensor.h"
//#include "Wire.h"
/* This driver uses the Adafruit unified sensor library (Adafruit_Sensor),
which provides a common 'type' for sensor data and some helper functions.
To use this driver you will also need to download the Adafruit_Sensor
library and include it in your libraries folder.
You should also assign a unique ID to this sensor for use with
the Adafruit Sensor API so that you can identify this particular
sensor in any data logs, etc. To assign a unique ID, simply
provide an appropriate value in the constructor below (12345
is used by default in this example).
Connections
Connect SCL to analog 5
Connect SDA to analog 4
Connect VDD to 3.3-5V DC
Connect GROUND to common ground
History
2015/MAR/03 - First release (KTOWN)
/* Set the delay between fresh samples */
#define BNO055_SAMPLERATE_DELAY_MS (100)
Adafruit_BNO055 bno = Adafruit_BNO055(55);
Displays some basic information on this sensor from the unified
sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
sensor_t sensor;
bno.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" xxx");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" xxx");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" xxx");
Serial.println("");
delay(500);
Arduino setup function (automatically called at startup)
void setup(void)
Serial.begin(115200);
Serial.println("Orientation Sensor Test"); Serial.println("");
/* Initialise the sensor */
if(!bno.begin()) {
// Spark.publish("debug","Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
/* There was a problem detecting the BNO055 ... check your connections */
while(1);
delay(1000);
/* Display some basic information on this sensor */
displaySensorDetails();
char buffer[100];
Arduino loop function, called once 'setup' is complete (your own code
should go here)
void loop(void)
/* Get a new sensor event */
sensors_event_t event;
bno.getEvent(&event);
/* Board layout:
| *| RST PITCH ROLL HEADING
ADR |* *| SCL
INT |* *| SDA ^ /->
PS1 |* *| GND | |
PS0 |* *| 3VO Y Z--> \-X
| *| VIN
/* The processing sketch expects data as roll, pitch, heading */
sprintf(buffer,"Orientation: %f %f %f", (float)event.orientation.x, (float)event.orientation.y, (float)event.orientation.z);
Spark.publish("debug",buffer);
/* Also send calibration data for each sensor. */
uint8_t sys, gyro, accel, mag = 0;
bno.getCalibration(&sys, &gyro, &accel, &mag);
// Serial.print(F("Calibration: "));
// Serial.print(sys, DEC);
// Serial.print(F(" "));
// Serial.print(gyro, DEC);
// Serial.print(accel, DEC);
// Serial.println(mag, DEC);
// Spark.publish("debug","Orientation: %f %f %f",(float)event.orientation.x,(float)event.orientation.y,(float)event.orientation.z);
// delay(BNO055_SAMPLERATE_DELAY_MS);
delay(1000);
@Rafael the code I posted with the library works for you? Still trying to figure it on my end…
OK I still have some issues. The Core works for lets say one minute delivering 3 axis of data, then very fast it disconnects and connects again with WiFi (only a blink of the led, one or two seconds). The Particle Dashboard shows the events device went offline and device came online.
Further I have problems to rebuild a working version. I’m lucky to still have the compiled firmware so I can flash it via USB, but if I rebuild, spark restarts after printing Orientation Sensor Test.
@chrobi you posted the Adafruit_Sensor.cpp above. Its the same file as Adafruit_Sensor.h from Adafruit Arduino library. Whats the difference between .h and .cpp files? Which one should be integrated, cause in the other files the Adafruit_Sensor.h is always the referenced file.
Hope to get this fixed and a working version again!!!
I’m thankful for any help!
