Accept data from web service to particle photon
Hi guys, do have a code sample that accept data from web service to photon?
thank you.
RDIF->Log System->Web service->Photon->Led matrix display names that come in.
Since you weren't that interested in elaborating any more on that other thread I'm just giving you the same answer
Just guessing… more details would be helpful. :point_left:
There is at least two avenues to having a Photon listen for outside data. If you would like a typical http connection, use https://docs.particle.io/reference/firmware/photon/#tcpserver and use port 80 instead of 23. Or, you could use a subscription service and then send web calls to Particle which should then get to the electron.
https://docs.particle.io/reference/firmware/photon/#particle-subscribe-
The latter is probably preferrered if the Photon is not directly accessible on the internet, say on a local home network.
