Was wondering was there was any further progress on this. I am from New Zealand as well, facing the same problem. I had rolled back the device OS to 1.5.2
Your device id is e00fce68ec8532de21c13612
Your system firmware version is 1.5.2
and still kept facing the same issues
0000023353 [app] INFO: deviceID: e00fce68ec8532de21c13612
0000023354 [app] INFO: PMIC inputVoltageLimit: 3880 mV
0000023355 [app] INFO: PMIC inputCurrentLimit: 500 mA
0000023356 [app] INFO: PMIC minimumSystemVoltage: 3500 mV
0000023357 [app] INFO: PMIC chargeCurrentValue: 896 mA
0000023358 [app] INFO: PMIC chargeVoltageValue: 4112 mV
0000033358 [app] INFO: modem is not yet responding
0000033362 [net.ppp.client] TRACE: PPP netif -> 8
0000033362 [hal] TRACE: Powering modem on
0000033512 [hal] TRACE: Modem powered on
0000033513 [hal] TRACE: Setting UART voltage translator state 1
0000034514 [ncp.at] TRACE: > AT
0000035514 [ncp.at] TRACE: > AT
0000036514 [ncp.at] TRACE: > AT
0000037514 [ncp.at] TRACE: > AT
0000038514 [ncp.at] TRACE: > AT
0000038518 [ncp.at] TRACE: < OK
0000039518 [hal] TRACE: NCP ready to accept AT commands
0000039518 [ncp.at] TRACE: > AT+UGPIOC?
0000039523 [ncp.at] TRACE: < +UGPIOC:
0000039528 [ncp.at] TRACE: < OK
0000039528 [ncp.at] TRACE: > AT+UGPIOR=23
0000039534 [ncp.at] TRACE: < +UGPIOR: 23,0
0000039534 [ncp.at] TRACE: < OK
0000039535 [hal] INFO: Using external Nano SIM card
0000039535 [ncp.at] TRACE: > AT+CPIN?
0000039539 [ncp.at] TRACE: < +CPIN: READY
0000039540 [ncp.at] TRACE: < OK
0000039540 [ncp.at] TRACE: > AT+CCID
0000039546 [ncp.at] TRACE: < +CCID: 8964011906077311284
0000039547 [ncp.at] TRACE: < OK
0000039547 [ncp.at] TRACE: > AT+COPS=3,2
0000041340 [app.help] INFO: Operator Selection (COPS) Set: mode=set format (3) format=numeric (2)
0000039552 [ncp.at] TRACE: < OK
0000039552 [ncp.at] TRACE: > ATI9
0000039558 [ncp.at] TRACE: < OK
0000039559 [hal] TRACE: App firmware: 204
0000039559 [ncp.at] TRACE: > AT+IPR=115200
0000039568 [ncp.at] TRACE: < OK
0000040569 [ncp.at] TRACE: > AT
0000040572 [ncp.at] TRACE: < OK
0000040572 [ncp.at] TRACE: > AT+IFC=2,2
0000040577 [ncp.at] TRACE: < OK
0000040577 [ncp.at] TRACE: > AT
0000040580 [ncp.at] TRACE: < OK
0000040581 [ncp.at] TRACE: > AT+UMNOPROF?
0000040588 [ncp.at] TRACE: < +UMNOPROF: 2
0000041354 [app.help] INFO: Mobile Network Operator Profile (UMNOPROF): AT&T (2)
0000040588 [ncp.at] TRACE: < OK
0000040589 [ncp.at] TRACE: > AT+URAT?
0000040596 [ncp.at] TRACE: < +CME ERROR: Operation not supported
0000040596 [ncp.at] TRACE: > AT+CEDRXS?
0000040601 [ncp.at] TRACE: < +CEDRXS:
0000040602 [ncp.at] TRACE: < OK
0000040602 [ncp.at] TRACE: > AT+CPSMS=0
0000040607 [ncp.at] TRACE: < OK
0000040607 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0000040614 [ncp.at] TRACE: < OK
0000040715 [ncp.at] TRACE: > AT
0000040766 [ncp.at] TRACE: < OK
0000040766 [hal] TRACE: NCP state changed: 1
0000040766 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000040767 [net.ppp.client] TRACE: PPP thread event ADM_DOWN
0000040767 [net.ppp.client] TRACE: PPP thread event ADM_UP
0000040768 [net.ppp.client] TRACE: State NONE -> READY
0000040770 [ncp.at] TRACE: > AT+CGDCONT=1,"IP","#########"
0000041373 [app.help] INFO: PDP context definition (CGDCONT): cid=1 pdpType=IP APN=#########
0000040816 [ncp.at] TRACE: < OK
0000040816 [ncp.at] TRACE: > AT+CEREG=2
0000041377 [app.help] INFO: EPS network (CEREG) Set to location enabled (2)
0000040866 [ncp.at] TRACE: < OK
0000040866 [hal] TRACE: NCP connection state changed: 1
0000040866 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN
0000040867 [ncp.at] TRACE: > AT+COPS=0,2
0000041384 [app.help] INFO: Operator Selection (COPS) Set: mode=automatic (0) format=numeric (2)
0000040916 [ncp.at] TRACE: < OK
0000040916 [ncp.at] TRACE: > AT+CEREG?
0000040966 [ncp.at] TRACE: < +CEREG: 2,2
0000041389 [app.help] INFO: EPS network (CEREG) Status: not registered, searching (2)
0000040966 [ncp.at] TRACE: < OK
0000040967 [ncp.at] TRACE: > AT+CGMI
0000041016 [ncp.at] TRACE: < OK
0000041016 [app] INFO: manufacturer: u-blox
0000041066 [app] INFO: model: SARA-R410M-02B
0000041117 [app] INFO: firmware version: L0.0.00.00.05.08 [Apr 17 2019 19:34:02]
0000041166 [app] INFO: ordering code: SARA-R410M-02B
0000041216 [app] INFO: IMEI: 354724644193150
0000041266 [app] INFO: IMSI: u-blox
0000041316 [app] INFO: ICCID: 8964011906077311284
0000041317 [app] INFO: Still trying to connect to cellular 00:07
0000041317 [app] INFO: Power source: USB Host
0000041319 [app] INFO: Battery state: charged, SoC: 100.00
0000051317 [app] INFO: Still trying to connect to cellular 00:17
0000051317 [app] INFO: Power source: USB Host
0000051319 [app] INFO: Battery state: charged, SoC: 100.00
0000055967 [ncp.at] TRACE: > AT+CEREG?
0000056016 [ncp.at] TRACE: < +CEREG: 2,2
0000056018 [app.help] INFO: EPS network (CEREG) Status: not registered, searching (2)
0000056016 [ncp.at] TRACE: < OK
0000061317 [app] INFO: Still trying to connect to cellular 00:27
0000061317 [app] INFO: Power source: USB Host
0000061319 [app] INFO: Battery state: charged, SoC: 100.00
0000067016 [ncp.at] TRACE: < +CEREG: 0
0000067019 [app.help] INFO: EPS network (CEREG) Status: not registered, not searching (0)
0000071017 [ncp.at] TRACE: > AT+CEREG?
0000071066 [ncp.at] TRACE: < +CEREG: 2,0
0000071068 [app.help] INFO: EPS network (CEREG) Status: not registered, not searching (0)
0000071066 [ncp.at] TRACE: < OK
0000071317 [app] INFO: Still trying to connect to cellular 00:37
0000071317 [app] INFO: Power source: USB Host
0000071319 [app] INFO: Battery state: charged, SoC: 100.00
0000081317 [app] INFO: Still trying to connect to cellular 00:47
0000081317 [app] INFO: Power source: USB Host
0000081319 [app] INFO: Battery state: charged, SoC: 100.00
0000086067 [ncp.at] TRACE: > AT+CEREG?
0000086116 [ncp.at] TRACE: < +CEREG: 2,0
0000086118 [app.help] INFO: EPS network (CEREG) Status: not registered, not searching (0)
0000086116 [ncp.at] TRACE: < OK
0000091317 [app] INFO: Still trying to connect to cellular 00:57
0000091317 [app] INFO: Power source: USB Host
0000091319 [app] INFO: Battery state: charged, SoC: 100.00
0000097916 [ncp.at] TRACE: < +CEREG: 2
0000097919 [app.help] INFO: EPS network (CEREG) Status: not registered, searching (2)
0000101117 [ncp.at] TRACE: > AT+CEREG?
0000101166 [ncp.at] TRACE: < +CEREG: 2,2
0000101168 [app.help] INFO: EPS network (CEREG) Status: not registered, searching (2)
0000101166 [ncp.at] TRACE: < OK
0000101317 [app] INFO: Still trying to connect to cellular 01:07
0000101317 [app] INFO: Power source: USB Host
0000101319 [app] INFO: Battery state: charged, SoC: 100.00
0000101388 [app.help] INFO: No compatible carriers found (searching for 01:00)
0000111317 [app] INFO: Still trying to connect to cellular 01:17
0000111317 [app] INFO: Power source: USB Host
0000111319 [app] INFO: Battery state: charged, SoC: 100.00
I have been trying to connect using both Vodaphone and Spark SIM cards, although the Boron gets stuck flashing Green. Was wondering how did it get along with you guys.
(Note: 0000040770 [ncp.at] TRACE: > AT+CGDCONT=1,“IP”,"#########" → That is me having edited the log. I am using a custom APN with which we are already sending data through other dev boards.)
Regards,
Joseph
