Is following solar panel suitable for use with Electron, or it can cause PMIC (or other) damage?
Open Circuit Voltage: 21.6V
Short Circuit Current: 1.23A
Maximum Power Voltage: 17.5V
Maximum Power Current: 1.14A
Peak Power Watts: 20
The Voc voltage is above recommended max input voltage, don’t do it. Get a lower voltage panel or voltage down converter to buck to 5v.
Added LM2596. Thnx.
