1 year after IoT.... Redbear duo looks difficult to install now
I got it work before. I started to play Xbox, watching youtube movies, enjoy vacation, etc.
Now, my redbear can’t go back particle.io I got the particle key.
I forgot document and fix it. I followed this. looks way difficult.
https://github.com/redbear/Duo/blob/master/docs/out_of_box_experience.md#using-serial-terminal
What I do now?
Po-Util works great with core, pi but… There is no particle cli tool for Redbear.
It Didn’t work.
Deducing device DFU version from functional descriptor length
ID 2b04:d058
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DfuSe interface name: "DCT Flash   "
Downloading to address = 0x00000022, size = 608
Download	[=========================] 100%          608 bytes
Download done.
File downloaded successfully
Saved!
attempting to add a new public key for device 1c00520009513xxxxxxxxxxxxxx
! Please login - it appears your access token may have expired
Error sending public key to server: Invalid token
Make sure your device is in DFU mode (blinking yellow), and that your computer is online.
Error - undefined
Token expired. Yucks… How do you fix this?
Have you tried logging back into particle-cli?
$ particle cloud login
I need tutorial how to DFU redbear.
With po-util?
Do whatever is possible on po-util. I removed particle device from IDE.
I want to see if po-util can do better job than dfu and particle cli.
This one failed… loss blinking light and can’t get in Particle IDE.
dfu-util -d 2b04:d058 -a 0 -s 0x8008000 -D fac-dct-r1.bin
dfu-util -d 2b04:d058 -a 0 -s 0x08020000 -D duo-system-part1.bin
dfu-util -d 2b04:d058 -a 0 -s 0x08040000 -D duo-system-part2.bin
dfu-util -d 2b04:d058 -a 2 -s 0x140000 -D duo-fac-tinker.bin
dfu-util -d 2b04:d058 -a 2 -s 0x180000 -D duo-wifi-r1.bin
particle keys doctor 1c00520009xxxxxx
Have you referred to the po-util quickstart guide?
It has steps to get started building firmware and flashing to your duo.
