Make sure you got the latest CLI (currently 1.19.4)
Then do particle update
via DFU Mode
Then, if particle setup
doesn’t work, try setting the device up step by step
particle identify
in Listening Mode to obtain the device ID -
particle serial wifi
in Listening Mode (decline all auto-support and choose manually) - device should breathe cyan now
particle device add <yourDeviceID>
particle device rename <yourDeviceID> <newName>
