When I try to set up my particle using the IOS app I end up getting the following screen
Since I get the same result every time I try setting up with IOS I tried manually setting up using the CLI. When I do that I get the following error:
Obtaining device information...
events.js:160
throw er; // Unhandled 'error' event
Error: connect ETIMEDOUT 192.168.0.1:5609
at Object.exports._errnoException (util.js:1022:11)
at exports._exceptionWithHostPort (util.js:1045:20)
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1087:14)v
Not really sure where to go from here. And ideas would be much appreciated.
