Spark.publish() for two spark cores
I have two spark cores - core1 and core2
When a input D0 in core1 is closed, i want to close a relay located on core2. I am think to use a spark.publish() function (i am right or exist another kind of function for that?) as communication between two cores. But after read Spark tutorials, i dont know how to do that with two spark cores.
Somebody can help me!?! :smile:
Thanks you very much!
Check out Spark.publish() and Spark.subscribe() at docs.spark.io :wink:
@kennethlimcp is correct.
Your code would be something like this (psuedo code)
Core 1:
int lastValue = -1;
setup()
    pinmode(D0, INPUT); // Pullup or pulldown perhaps?
loop()
    int newValue = digitalRead(D0);   // also need somekind of debounce code here
    if(newValue != lastValue)    // The value has changed
        if(newValue == HIGH)
            Spark.publish("D0","HIGH");
        else
            Spark.publish("D0","LOW");
        lastValue = newValue;
Core 2:
void myHandler(const char *event, const char *data)
    if(data == "HIGH")
        digitalWrite(D1,HIGH);
    else
        digitalWrite(D1,LOW);
    pinmode(D1,OUTPUT);
    Spark.subscribe("D0", myHandler, MY_DEVICES);
I believe this does pretty much exactly what you’re trying to achieve. It’s also commented nicely. Definitely check it out!
