Hey Guys I am stuck. I can’t get my cores to respond with each other. The scenario is that when I touch one of the core the other cores should blink and vice versa. So I have read the documents and seen a lot of similar examples but I am stack I can not get it to execute. I think I am missing something I have used this posts to get an idea, any help is appreciated thanks in advance.
- List item
http://community.spark.io/t/spark-subscribe-attempt/4852/13
http://www.hackster.io/maxeust/quantumly-entangled-leds1
http://blog.spark.io/2014/05/12/subscribe-and-hackster/
Here is my code
Code for core1
// Which I/O pins are we using
#define zPin A2
#define Dpin D1 // Input pin for the led to blink when its moved
//Minimum and Maximum data for the Z axes- the accelerometer
int zAccMin = 1722;
int zAccMax = 2400;
int sendLedPin = D1; // Blinks when accelerometer is touched
int zAccPin = zPin; // Value for reading the data for the Z axe
int receiveLedPin = D2; // The pin that blinks when it receives.
Serial.begin(9600); // sets the serial port to 9600
pinMode(zAccPin, INPUT);
pinMode(receiveLedPin, OUTPUT);
pinMode(sendLedPin, OUTPUT);
Spark.subscribe("motionDetected2", ledTwoToggle, MY_DEVICES);
zAccPin = analogRead(zPin); // read the value of the Z axe sensor
if(zAccPin == (zAccMin) || zAccPin < (zAccMax)){ // If core1 is lifted up
digitalWrite(sendLedPin, HIGH);
Spark.publish("motionDetected1","ON");
Serial.print("Zaxe is ActiveCORE1 "); //Debug
Serial.print("\t");
delay(100);
else
digitalWrite(sendLedPin, LOW);
Spark.publish("motionDetected1","OFF");
Serial.print("Zaxe is NotActiveCORE1"); //Debug
Serial.print("\t");
delay(100);
void ledTwoToggle(const char *event, const char *onOff){
if (strcmp(onOff,"ON"))
digitalWrite(receiveLedPin, HIGH);
} else if (strcmp(onOff, "OFF")) )
digitalWrite(receiveLedPin, LOW);
For core 2 its similar to cores 1
#include "application.h"
#define zPin A2
//Minium and Maxium data for the axes- the accelerometer
int zAccMin = 1722;
int zAccMax = 2400;
int zAccPin = zPin;
pinMode(receiveLedPin , OUTPUT);
Spark.subscribe("motionDetected1", ledTwoToggle, MY_DEVICES);
Spark.publish("motionDetected2", "ON"); //Publish the state to the Spark Cloud as ON
Serial.print("Zaxe is ActiveCORE2 "); //Debug
Serial.print(zAccPin); //Debug
Serial.print("\t");
delay(250); // Primitive debouncing
} else{
Spark.publish("motionDetected2","OFF");
Serial.print("Zaxe is NotActiveCORE1"); //debug
Serial.print("\t");
delay(100);;
void ledTwoToggle(const char *event, const char *onOff){ //Handler function for Spark.subscribe ()
if (strcmp(onOff,"ON")) ){
} else if (strcmp(onOff, "OFF")) {
Any help is appreciated
Meth
