Change Photon SSID
I have following the instructions:
I have installed the DFU driver (windows x64)
The prompt, etc.
When I write:
#echo -e -n "\x03Rad" > ssid_prefix (It's OK)
When I try to upload in the dfu:
#dfu-util -d 2b04:d006 -a 1 -s 1826 -D ssid_prefix
I receive the following:
Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2012 Tormod Volden and Stefan Schmidt
Filter on vendor = 0x2b04 product = 0xd006
Opening DFU capable USB device... ID 2b04:d006
Found DFU: [2b04:d006] devnum=0, cfg=1, intf=0, alt=1, name="@DCT Flash   /0x000
00000/01*016Kg"
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
No valid DFU suffix signature
#Warning: File has no DFU suffix
DfuSe interface name: "DCT Flash   "
Downloading to address = 0x00000722, size = 18
File downloaded successfully
When I reset the device and set it on listening mode it continues appearing the standard name.
I have tried with the lib… driver for photon dfu and with the windows… driver which Zadig propose. Both options generates the same. I think it is not related with it.
I have also tried to modify the serial following your example and the name of the serial has been modified to:
Photon--n "
So, it seems the name has been (-n "), the four characters (instead of 6) before “ABCDEF”. I have modified the echo serial line from:
echo -n "ABCDEF" > serial
to:
echo ABCDEF > serial
And when I try with:
dfu-util -d 2b04:d006 -a 1 -s 1852:6 -D serial
The SSID has changed to: Photon-ABCD
In the serial it seems that the maximum is 4 letters (unless in firmware 0.4.7). It is not a problem for me.
I do not know if something related with the SSID Prefix has changed @mdma
We are ending a product development and this is possible the last step. Any help will be hardly appreciated.
Thank you very much
@Moors7: in the future, PLEASE use some formatting in your posts. This one was really hard to read.
I have just achieved in a Ubuntu 14.04 machine without problems :smiley:
It would be great if you could complete @mdma instructions for Windows User.
@mdma could you share the ETA when it will be available via code? We are planning to ship a 1000 particle based products to our customers and it’s going to be painful for us to rename each of them via DFU mode. I have the same scenario as @henkep
I just did this today with the code below.
System.set(SYSTEM_CONFIG_SOFTAP_PREFIX, "Gizmo");
Edit: removed the code to check the value was already set since @mdma mentioned that System.set does it by itself.
Do you need the check? System.set() checks if the data to be written is the same as what is already present, so it’s not causing flash wear.
I updated my post. Thanks.
I see that I can set the prefix and suffix manually right now with:
System.set(SYSTEM_CONFIG_SOFTAP_PREFIX, "hello");
System.set(SYSTEM_CONFIG_SOFTAP_SUFFIX, "hello");
However I was wondering how the factory suffix from the Photon was generated? Is this a part of the DeviceID (which is a lot more characters) that I can get with System.deviceID();?
I’d like to use mDNS / Bonjour to discover my Photon and was thinking to use the preconfigured suffix. However there is no System.get command in the firmware I think, since it seems commented out in the code: https://github.com/spark/firmware/blob/27dec24644c58935af728b00adb742f7d18a5b86/user/tests/wiring/api/system.cpp
The suffix is generated using the RNG build into the device.
So the best way to use a suffix which I can use in the mDNS name and the SSID name is to generate a new one myself? There is no getter function? I found the location in Flash, however that might be not so smart (I don’t know if that will change in future firmware releases).
I suppose this is the code you use to generate the number isn’t?
void random_code(uint8_t* dest, unsigned len) {
    unsigned value = HAL_RNG_GetRandomNumber();
    bytesToCode(value, (char*)dest, len);
That’s it - https://github.com/spark/firmware/blob/develop/hal/src/photon/softap.cpp#L757-L760
@kasper Hi! I’ve been bumping into the same trick, wanting to save the SSID suffix to the phone client so after softap setup I could use that in mdns.
What did you end up doing? Reading ala ‘fetch_or_generate_device_code’ and using that in your setup? Would you mind sharing your solution?
@mterrill I didn’t implement it yet. It’s not my top priority and I decided to wait for an API implementation. However that is now already postponed to version 0.8.
@mdma any ETA on System.get ? Ideally would read back the SSID prefix/suffix in code for display on an OLED and would rather not hard-code it.
I resorted to pulling a few of the more entropic parts of the device ID to generate a consistently-different 6-character suffix. Not perfect, but sufficient for my small fleet of photons:
String prefix = "Custom"
String suffix = "";
  System.set(SYSTEM_CONFIG_SOFTAP_PREFIX, prefix);
  String id = System.deviceID();
  suffix = id.substring(0,2) + id.substring(4,6) + id.substring(8,10);
  System.set(SYSTEM_CONFIG_SOFTAP_SUFFIX, suffix);
String getSSID() {
  return prefix + "-" + suffix;
