I’m attempting to run some row/column lighting effects with the WS2812 libraries and the core keeps flashing red after wifi connect. Looks to be an S-O-S pattern, followed by a few steady flashes. I see that there might be some RAM issues, so I’m wondering if anybody could confirm that this is what I’m running into!
Each pixel is assigned to an array position depending on its x/y coordinates… so I suspect that the lightgrid[50][15] variable might be a little big, though I am totally unsure.
Code is as follows:
#include "Spark_NeoPixel.h"
/* ======================= Includes ================================= */
#include <application.h>
/* ======================= Prototype Defs =========================== */
void colorAll(uint32_t c, uint8_t wait);
void colorWipe(uint32_t c, uint8_t wait);
void rainbowCycle(uint8_t wait);
uint32_t Wheel(byte WheelPos);
int tinkerDigitalRead(String pin);
int tinkerDigitalWrite(String command);
int tinkerAnalogRead(String pin);
int tinkerAnalogWrite(String command);
/* ======================= Spark_StrandTest.cpp ===================== */
#define PIN D0
Adafruit_NeoPixel strip = Adafruit_NeoPixel(56, PIN, WS2812);
int cRed=0;
int cGrn=0;
int cBlu=0;
int timOut = 10;
int timCycle = 20;
int countdown;
bool colorUpdated = 0;
bool rainbowMode = 0;
bool clearStrip = 0;
int lightgrid[50][15];
void loadLightGrid(){
// ..grid[xx][y] = LED_sequence_num;
lightgrid[42][1] = 33;
lightgrid[42][3] = 34;
lightgrid[13][6] = 12;
lightgrid[22][6] = 19; // O in
lightgrid[24][6] = 26; // O out
lightgrid[29][6] = 27; // R in
lightgrid[31][6] = 28;
lightgrid[33][6] = 29;
lightgrid[38][6] = 44;
lightgrid[40][6] = 45; // D out
lightgrid[42][6] = 35;
lightgrid[45][6] = 54;
lightgrid[47][6] = 53;
lightgrid[6][7] = 7;
lightgrid[8][7] = 8;
lightgrid[10][7] = 9;
lightgrid[12][7] = 11;
lightgrid[36][7] = 43;
lightgrid[42][7] = 36;
lightgrid[48][7] = 52;
lightgrid[5][8] = 6;
lightgrid[14][8] = 18;
lightgrid[16][8] = 14;
lightgrid[20][8] = 20;
lightgrid[26][8] = 25;
lightgrid[29][8] = 30;
lightgrid[5][9] = 5;
lightgrid[42][9] = 37;
lightgrid[45][9] = 47;
lightgrid[47][9] = 46; // A in
lightgrid[6][10] = 4;
lightgrid[8][10] = 2;
lightgrid[10][10] = 1; // CA in
lightgrid[12][10] = 10;
lightgrid[20][10] = 21;
lightgrid[26][10] = 24;
lightgrid[29][10] = 31;
lightgrid[36][10] = 42;
lightgrid[48][10] = 51;
lightgrid[7][11] = 3;
lightgrid[41][11] = 39;
lightgrid[13][12] = 17;
lightgrid[15][12] = 16;
lightgrid[16][12] = 15;
lightgrid[22][12] = 22;
lightgrid[24][12] = 23;
lightgrid[29][12] = 32; // R out
lightgrid[38][12] = 41;
lightgrid[40][12] = 40;
lightgrid[42][12] = 38;
lightgrid[45][12] = 48;
lightgrid[47][12] = 49;
lightgrid[48][12] = 50;
} // loadLightGrid
void showColor() {
colorUpdated = 1;
countdown = 1000;
Spark.function("digitalwrite", chageLEDPattern);
Spark.function("analogwrite", updateRGBLEDColor);
//Spark.variable('lightgrid_1_1', &lightgrid[1][1], STRING);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
loadLightGrid();
if( colorUpdated == 1){
colorAll( strip.Color(cRed, cGrn, cBlu), timOut);
colorUpdated = 0;
if( rainbowMode == 1){
rainbowCycle(timCycle);
if( clearStrip == 1){
colorAll( strip.Color(0,0,0), 0);
clearStrip = 0;
* Function Name : updateRGBLEDColor
* Description : Overrides analogWrite for display purposes
* Input : Pin and Value (0 to 255)
* Output : None.
* Return : 1 on success and a negative number on failure
int updateRGBLEDColor(String pinAndValue) {
int pinNumber = pinAndValue.charAt(1) - '0';
int value = pinAndValue.substring(3).toInt();
if( value > 255)
value = 255;
if (5 == pinNumber)
cRed = value;
else if (6 == pinNumber)
cGrn = value;
else if (7 == pinNumber)
cBlu = value;
else if(1 == pinNumber)
timCycle = value;
else if(0 == pinNumber)
timOut = value;
showColor();
return 0;
* Function Name : changeLEDPattern
* Description : Override digitalWrite call
* Input : Pin and value
* Output : None.
int chageLEDPattern(String command){
int pinNumber = command.charAt(1) - '0';
//Sanity check to see if the pin numbers are within limits
if (pinNumber< 0 || pinNumber >7) return -1;
/* Deal with this later...
bool value = 0;
//convert ascii to integer
if(command.substring(3,7) == "HIGH") rainbowMode = 1;
else if(command.substring(3,6) == "LOW") rainbowMode = 0;
else return -2;
if(command.startsWith("D"))
//pinMode(pinNumber, OUTPUT);
//digitalWrite(pinNumber, value);
return 1;
else if(command.startsWith("A"))
//pinMode(pinNumber+10, OUTPUT);
//digitalWrite(pinNumber+10, value);
return 1;
if( (pinNumber == 7) && (command.substring(3,7) == "HIGH") ){
rainbowMode = 1;
} else if( (pinNumber == 7) && (command.substring(3,6) == "LOW") ){
rainbowMode = 0;
clearStrip = 1;
} else if( (pinNumber == 0) && (command.substring(3,6) == "HIGH") ){
rowWipe( strip.Color(cRed, cGrn, cBlu), 500);
} else if( (pinNumber == 1) && (command.substring(3,6) == "HIGH") ){
colWipe( strip.Color(cRed, cGrn, cBlu), 500);
else return -3;
* Custom NEOPIXEL functions
// Set all pixels in the strip to a solid color, then wait (ms)
void rowWipe(uint32_t c, uint8_t wait) {
uint16_t i;
// for(i=0; i<strip.numPixels(); i++) {
// strip.setPixelColor(i, c);
// strip.show();
delay(wait);
void colWipe(uint32_t c, uint8_t wait) {
uint16_t i;
uint16_t j;
for(i=1; i<48; i++) {
for(j=1; j<12; j++) {
if( lightgrid[i][j] > 0 ){
strip.setPixelColor( lightgrid[i][j], c);
strip.show();
delay(wait);
* NEOPIXEL FUNCTIONS
void colorAll(uint32_t c, uint8_t wait) {
uint16_t i;
strip.show();
delay(wait);
// Fill the dots one after the other with a color, wait (ms) after each one
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout, then wait (ms)
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) { // 1 cycle of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
Any and all insight welcome! Thanks for your time guys
