Ahhh nightmare. Oh well… it was useful while it lasted
OK, now I’m confused. As far as I know (and have done a couple of times), the .BIN file is what you flash with dfu-util, and it sends every byte of the file over. From my experience with the arm-none-eabi toolchain (a la DevKitPro, for programming the Nintendo GameBoy Advance–it’s a really handy little machine!), the output BIN is exactly what goes on to the GameBoy.
Admittedly, in every single past project (microprocessor or GameBoy Color/Advance), I’ve always ended up getting so frustrated with the compiler that I ended up programming the entire project in Assembler. Most compilers/IDEs tend to pack an incredible amount of “baggage” onto an empty project, generally 60K+. . .C/C++ and I are not the best of friends.
I actually wrote my largest GBA project in pure ARM7TDMI assembler: 718KB of source code (15,541 lines) plus a 10KB compressed helpfile resulting in a 47K output BIN. (And yes, I do heavily comment ASM code!) That was a complete BASIC/ASM IDE on the little GBA, making it a pretty handy little debug terminal. (The link port on the back can serve as RS-232, shift-clock, or 4 GPIOs.)
@WebDust21, are you building for the Photon? According to this post by @mdma, sprintf has been moved to the system firmware for the develop branch, so it’s possible (I’m not sure what firmware the cloud/ide is building against) that sprintf is already included, so adding that line doesn’t change the user-part.bin at all.
No, I’m building for the Core. (I will be building for the Photon in the future.) I also am not including <string.h> in the project. If I’m not using x=String(); or the typedef “String var;”…theoretically that library shouldn’t be included, either? FWIW I don’t get an error for not including <string.h> in a project referencing it.
@mdma sprintf has been moved to system firmware? I seem to recall reading another post last night saying that sprintf(); was being deprecated for 0.4.0 to save the 20KB of firmware space. Unfortunately, I can’t find that post, either…
Or are all libraries (including the non-used I2C, SPI, etc.) now being included no matter what? Does this mean that I need to figure out how to compile the Core firmware myself in order to manually exclude the unused libraries?
P.S. I don’t think I’m going to go the ASM route on this one. It’s not worth reinventing the wheel, inner tube, tire, valve stem, Schrater valve…AND the air to inflate the tire
@mumblepins, I found the post that I was referencing, in which @mdma wrote that sprintf() support FOR FLOAT will be removed from 0.4.0. Reading closer sometimes helps Issues with converting float to string with sprintf
But do we yet have a solution for unnecessarily large firmware due to unused libraries? I’m aware that the Particle IDE builds the project in the , meaning that I can’t just rename some firmware header files on my local system to exclude them from the build. Perhaps Particle IDE just needs an #exclude directive!
@WebDust21, oops . FWIW, it’s pretty straightforward to setup a local build environment, especially for the Core. For one of my projects, I had to do that and strip out a lot of things, even including the whole serial port interface (which made debugging a bit tricky at times, I must admit). See here for the toolchain.
I wasn’t referring to you on the post by mdma…I was referring to my former post about misunderstanding sprintf support as being deprecated in 0.4.0. Nothing personal .
I’m glad to hear that it’s pretty straightforward to setup a local build environment. devKitPro was the very first toolchain that I was successfully able to install and use. If I start running out of memory, I guess that’ll be my first stop. I don’t think I could get away with removing serial port support–you’re a brave programmer to do that! Thanks for the link.
@kennethlimcp I'm looking inside a compiled BIN file, and there's 537 bytes consumed with the following plain-text message:
** Even though the CC3000 supposedly supports WEP,
** we at Spark have never seen it work.
** If you control the network, we recommend changing it to WPA2.
Thanks! Wait about 7 seconds while I save those credentials...
Awesome. Now we'll connect!
If you see a pulsing cyan light, your Spark Core
has connected to the Cloud and is ready to go!
If your LED flashes red or you encounter any other problems,
visit https://www.spark.io/support to debug.
Spark <3 you!
Your core id is {"f":,"v":{ ": }}
Did someone's code comments somehow get included into the project? As far as I know, there's no way the Core/Photon could tell you any of the above if it wasn't connected to the network, or was having problems. What in the world is this?
Everyone: you can check your BIN files in a plain-text editor. Turn word-wrap on, and down at the bottom of the file, you'll see the above text.
Well, this is what the serial terminal says when you input the Wifi credentials manually. So I’m guessing that’s what it is? Unless I’m misunderstanding you…
OK, I forgot about that…
…but I’m watching the “space remaining” gauge count down, and was eying what looked to be some potential optimization!
Yup i’m sure we can strip those out to save some space
