Writing a variable number of bytes to the emulated EEPROM
For device OS 4.2.0, I'm trying to write a function that writes a variable amount of bytes to the emulated EEPROM using EEPROM.put(address, object). In my implementation, it appears that the struct that is passed needs to be statically defined ahead of time. What's the recommended way to achieve this? I've come up with two ideas and wanted to point out the issues with each that I encountered.
  1. Putting fixed blocks of 64 bytes and then writing individual bytes one-by-one that don't fit into the block size. The problem is there's a delay for each EEPROM.put() or EEPROM.write() call, which I imagine is because the whole file is being written at once per documentation. The only improvements I could think of is to make multiple block sizes to prevent the least amount of writes.
  2. Reading the full 4096 bytes into a struct, modifying the necessary bytes, the writing the whole 4096 byte struct. This is fast, but there was software that worked before, but it goes into SOS Panic mode when it gets to the EEPROM.get() call in some cases.
Ideally, it'd be great if there was a way to pass a pointer and a size so the writes could be variable for EEPROM.put(address, pointer, size).
Would it be possible for you to use a file instead of EEPROM?
Like Gus said, using the file system API is the correct solution here. On Gen 3 devices including the Monitor One, writing to the EEPROM just writes the data to a file on the same flash file system anyway, so the performance will be nearly identical.
However the file system API is designed to write variably-sized data easily.
I checked with the customer, and they need at least part of what they're storing on an EEPROM. So, I think I might have to go with the I/O card's EEPROM. Thank you!
I saw this example. Is this still the way to go about it?
Hi, I would insist, since it's the same thing. Whatever you write in the file system will survive resets, absence of power. And these days EEPROM is simulated and uses the file system under the hood.
Perhaps the customer has another requirement that of course I am unaware of.
UNLESS you are using an older device (Gen 2).
Best,
There is a Standard I/O card provided by Particle for the MonitorOne that has a EEPROM on it. Are you saying no code exists for using that EEPROM?
The Tracker SoM has a flash memory chip on it, part of which contains a flash file system for persistent data (4 MB).
Instead of adding another EEPROM chip, the EEPROM calls just write to that flash file system. It's really fast quad SPI flash, it's much faster than a real EEPROM.
Thanks Rick,
please reference I/O card - it's a daughter card with some I/O expansion
There is a EEPROM on this card.
Yes, but that's not really intended for user data storage. It's designed to hold the card ID or maybe card-specific calibration data. It's 8 Kbytes and relatively slow.
If you do really want to use it, the first 64 bytes are reserved for this structure; make sure you don't overwrite it.
struct ExpansionEeprom1 {
    uint16_t    size;           ///< Size of entire ExpansionEeprom
                                ///< structure. LSB, MSB
    uint8_t     revision;       ///< Revision number of this hardware
                                ///< starting from 1
    char        sku[29];        ///< SKU name with null termination
    uint8_t     serial[16];     ///< 128-bit serial number MSB->LSB
    uint8_t     reserved[16];   ///< Page boundary filler
} __attribute__((packed));
There's more information in the README in Monitor Edge. There are functions in eeprom_helper.h to read and write it.
Thank you very much Rick
Thank you! That helps as two potential paths. The EEPROM on the I/O card if it's truly needed vs. the file system usage.
