Working with TX output and SparkFun 7-Seg Serial Display [SOLVED - wiring issue]
I recently purchased a serial 7-seg display from SparkFun.
The code I’m working with is below:
int cycles = 0;
    pinMode(TX, OUTPUT);
    Serial1.begin(9600);
    Serial1.write('v');
    cycles++;
    char tempString[10];
    sprintf(tempString, "%4d", cycles);
    Serial1.write(tempString);
    delay(2000);
It’s probably extremely obvious what I’m doing wrong, but I for the life of me can’t figure this out.
I have my VIN connected to the 7-Seg’s VCC, my GND connected to the 7-Seg’s GND, and my TX connected to the 7-Seg’s RX.
In the Arduino world, there is a big difference between Serial1.write() which sends a single character and Serial1.print() which sends the whole string. I think you want Serial1.print(tempString); instead of write().
Can you try changing that?
I did, and it still doesn’t make a difference. The 7-seg display is still showing all zeroes.
OK have you tried something like the Sparkfun example, skipping all the other stuff for now?
Serial1.print("-HI-");
It still doesn’t do anything. Just all zeroes on the display.
Got it working, my pins weren’t making a secure connection.
