Working with the Sparkfun Photon IMU Shield
@u2pride, SparkFun has just pushed a new version of their library to their GitHub repo, but not yet to Web IDE.
Can you give it a try?
@ScruffR, I don’t see any update on their github!?
That’s the repo and I asked them to push it to Web IDE
https://github.com/sparkfun/SparkFun_LSM9DS1_Particle_Library
Unfortunately the corrections only apply to the SPI demo, but maybe if the I2C pins have issues @u2pride might like to give SPI a shot.
@ScruffR, all they did was fix the default CS for SPI. However, I do agree that if I2C is a problem, then the OP could try SPI instead. From the OP’s pictures, I can’t see anything wrong with the board. His problems may be power supply related or some other factor not discussed like protoboard problems if he is using one. :smile:
@ScruffR @peekay123 thanks for the heads up. I’ve unfortunately moved on to using an arduino and adafruit sensors.
Pitty :weary:
But you have to get your results - hope to see you back from the Dark Side soon :wink:
