I am having strange result from WiFi.scan() function in my firmware.
My code is as follows.
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(SEMI_AUTOMATIC);
STARTUP(System.enableFeature(FEATURE_ETHERNET_DETECTION));
#ifdef ETHERNETCONN
Ethernet.on();
Ethernet.connect();
#endif
Particle.connect();
delay(2000);
Serial.begin(115200);
Serial.println(F("Particle Argon WiFi scanning..."));
void wifi_scan_callback(WiFiAccessPoint* wap, void* data)
WiFiAccessPoint& ap = *wap;
Serial.print("SSID: ");
Serial.println(ap.ssid);
Serial.print("Security: ");
Serial.println(ap.security);
Serial.print("Channel: ");
Serial.println(ap.channel);
Serial.print("RSSI: ");
Serial.println(ap.rssi);
static uint32_t ethernetCheckTime = millis();
if(millis() - ethernetCheckTime > 10000)
int result_count = WiFi.scan(wifi_scan_callback);
Serial.print(result_count);
Serial.println(" APs scanned.");
I am getting following result in serial monitor.
-210 APs scanned.
Strange is that, if I setup WiFi credential in tinker app and module has connected to cloud,
I can getting valid result.
6 APs Scanned.
SSID: XXXX
Channel: x
RSSI: -23
SSID: XXXX
Channel: x
RSSI: -45
I am not sure, what is issue within usage WiFi.scan() in my code.
Thanks.
