Wifi softAp - http setter
I’m developing a firmware that needs to be configured. It’s a simple configuration, only a couple of int vars to be written in eeprom. Sometimes there is no wifi connection, so I need another way to and save and read those vars…
Watching around I found this
There is a setter method, that only accepts cc key, that works in AP mode…
Is possible to change that to call a custom function and to pass it the key-value received from the setter method? I believe that are only a few lines of code in the firmware, but I don’t know how to call a function in my code from the particle firmware…
In this way It should be possible to configure the photon in softAP mode and eventually, with a getter method, to get the value of some vars…
Has anyone done already something like that?
Thanks a lot
Flavio
I want to open up the HTTP server that is made available during SoftAP mode so that applications can add their own functionality there. Would that provide what you’re looking for?
It would be perfect! It’s a new request or it’s somenthing you are already looking into?
Right now I modified the method set to write on eeprom and it works, but something more generic it’s the best idea…
Thanks a lot
Flavio
Will it be available in 0.5.0?
Yes! The PR is here - https://github.com/spark/firmware/pull/906
