I’m using a nextion screen and trying to add a button to enable/disable listening mode.
Once I enable WiFi.listen() through a callback, the photon no longer communicates with the screen (uses Serial1). Anyone else see this happening? I’m starting to dig through the particle source to see if it’s turned off there.
