I have an issue …I am Particle publishing 3 x voltage data 3x Current data, 1 x Altimeter data and 1 x Accelerometer data and 1 x Temps but only One voltage /Current temp and altimeter is showing up on Particle cloud …Is there a reason for this ??
Are you violating the once per second (or burst of 4) rate limit for publishes?
You could combine all those events into one.
Yes, this is the way to go.
Get it all out in a single publish event.
I send basically the full 255 bytes of data every 10 seconds and Losant.com receives it and updates my dashboard. Works perfectly.
Exactly how do I combine my publishes ?
There are multiple ways.
My preferred way is via snprintf()
See if this helps any, its what I had to learn to accomplish a custom publish event string.
Thanks for that …Ok so how do you separate the data between the colons after the publish ?
Thanks you have an example …Extreme newbie here
I show you how to do in the link I posed above.
