Which pin to use for AREF using an ADXL335 with Photon
So I want to use the ADXL335 with my new photon to play with some game control ideas. I’m not sure where to (or if I even have to) connect to an AREF on the photon? Do I need an AREF for my accelerometer and, if so, which pin would I use?
AFAIK the AREF is only needed on 5V Arduinos to adjust their ADC for 3V3, but since the Core and Photon already run on 3V3 you won’t need it.
Thanks ScruffR, That’s what I was starting to read as well from other sites.
