Where do I place the API key in the Webhook settings?
The answer depends on how you intend to use the webhook.
The common use case (for myself anyway) is to send the ThingSpeak API Write key with every publish.
That way, you will only need 1 webhook to send data to any ThingSpeak Channel.
This Post/Thread may help you:
The Webhook definition is a few posts below it.
