Hi, I just noticed that under the abs function the description is as follows :
“Computes the absolute value of a number.abs(x); where x is the number The function returns x if x is greater than or equal to 0 and returns -x if x is less than 0.”
the absolute value should never be negative if I’m not mistaken ?
ahhh now it makes sense, I’m having issues with the decimals disappearing - is that a result of the abs() function ? - or the numbers after the decimal point turning into 0
On Spark right now, abs() is a macro so you can have problems if you put certain operations inside the parens–the doc gives the example abs(a++) as being something to avoid. I don’t know of a way that abs() could lose precision, though.
If you are having problems, I would make sure that your taking abs() of just a variable: y = abs(x); so that nothing bad can happen.
If you want to post some code, we can have a look and try to help.
What types are accDifference[] and differenceSum in your code above?
C has a rule for the += operator that the right hand side is always cast into the left hand side’s type before the operation is performed, so if I had guess, that is where your problems is.
accDifference is an array of floats and differencesum is a float - so it shouldn’t be typecasting anything ?
float accDifference[3];
unsigned long Now = millis(); // Used to compare to last punch
// check to see if there is a previous value before calculating differences
if(on == false){
for(int i = 0; i < 3; i++){
prev[i] = array[i];
on = true;
else if(Now - lastPunch > punch_delay) {
float difference = array[i]-prev[i];
accDifference[i] = abs(difference);
differenceSum += accDifference[i];
prev[i] = array[i];
filterSignal(accDifference);
Yes, abs() is integer while fabs() is float. While fabs() is standard C, the spark docs do not mention it specifically so I can’t say if it is implemented. Worth a test, though.
