What rfid readers do you recommend to use with the Photon?
Thank you so much. Its working now. I’ll post the code here for anyone who’d want to use the Parallax reader in future (Y). :smile:
int  val = 0;
char code[10];
int bytesread = 0;
int num;
int enable = D4;
int read;
    Serial1.begin(2400);
    pinMode(enable,OUTPUT);
    digitalWrite(enable, LOW);
    read = 1;
    if(Serial1.available())
        if((val = Serial1.read()) == 10 && (read))
            bytesread = 0;
            read = 0;
            while(bytesread<10)
            {              // read 10 digit code
                 if( Serial1.available() > 0)
                    val = Serial1.read();
                    if((val == 10)||(val == 13))
                        break;                       // stop reading
                    code[bytesread] = val;         // add the digit
                    bytesread++;                   // ready to read next digit
            if(bytesread == 10)
                Particle.publish("Tag Code",code);
            bytesread = 0;
            digitalWrite(enable, HIGH);     // deactivate the RFID reader for a moment so it will not flood
            delay(3000);                    // wait for a bit
            digitalWrite(enable, LOW);      // Activate the RFID reader
        read=1;
Hi there. I am having some problems in using the RFID reader. Right now, I am trying to access control an LED and FAN with two RFID card readers. So ideally if I swipe Card A once, it should turn ON the Led and on the next swipe it should turn OFF the led. And the same applies to controlling the FAN using RFID card 2. However, it seems that the Serial1.Available function detects the card twice on a single swipe, due to which it sends the command twice for controlling the LED/FAN. So it will momentarily switch ON the led/fan and then switch it off. Also, the serial1.available function returns null every time even after swipping the RFID card. So if you could help me with it please, it would be great. Thanks in advance :smile:
Here is my code snippet:
#include "PietteTech_DHT/PietteTech_DHT.h"
#include "RelayShield/RelayShield.h"
#define DHTTYPE  DHT22
#define DHTPIN   D1
RelayShield myRelays;
void dht_wrapper();
PietteTech_DHT DHT(DHTPIN, DHTTYPE, dht_wrapper);
int lastPub;
int temp;
int hum;
float current;
uint16_t messageid;
int  val = 0;
char code[10];
int bytesread = 0;
int num;
int enable = D0;
int read;
int led = D7;
int Relay=D3;
double potentiometer;
int light_status=0;
int fan_status=0;
      myRelays.begin();
  //  Serial.begin(9600);
    read = 1;
    pinMode(led, OUTPUT);
    pinMode(Relay, OUTPUT);
    String FanAccessKey="2600D610B3";
    String LightAccessKey="02007F6479";
//int mVperAmp = 66; // use 100 for 20A Module and 66 for 30A Module
//int ACSoffset = 2500;
   DHT.acquire();
    hum = DHT.getHumidity();
    temp = (DHT.getFahrenheit()-32)*5/9;
    potentiometer= (analogRead(A0) * 3.3 )/4095 ; // current = ((current - ACSoffset) / mVperAmp);
 // if ( (millis() - lastPub) > 2000 ) //It publishes every 2 secs
        Particle.publish("Humidity", String(hum) + "%");
        Particle.publish("Temperature", String(temp) + " °C");
        Particle.publish("Frob knob: ", String(potentiometer)  +"V");
        //lastPub = millis();
      Particle.publish("Swipe now","Ready");
     while(Serial1.available())
       Particle.publish("Serial.Available is ", Serial1.available());
        if((val = Serial1.read()) == 10)
            bytesread = 0;
            while(bytesread<10)
            if(bytesread==10)
                //2600D610B3
                if(code[0]=='2' & code[1]=='6' & code[2]=='0' & code[3]=='0' & code[4]=='D' & code[5]=='6' & code[6]=='1' & code[7]=='0' & code[8]=='B' & code[9]=='3')
                    if(light_status==0) // Heater is OFF
                        Particle.publish("Turning led","on");
                        digitalWrite(led, HIGH);
                        light_status=1;
                    else if(light_status==1)
                        Particle.publish("Turning led","OFF");
                        digitalWrite(led, LOW);
                        light_status=0;
                //02007F6479
                else if(code[0]=='0' & code[1]=='2' & code[2]=='0' & code[3]=='0' & code[4]=='7' & code[5]=='F' & code[6]=='6' & code[7]=='4' & code[8]=='7' & code[9]=='9')
                    if(fan_status==0) // Heater is OFF
                        Particle.publish("Turning Fan","on");
                        digitalWrite(Relay, HIGH);
                        fan_status=1;
                    else if(fan_status==1)
                        Particle.publish("Turning fan","OFF");
                        digitalWrite(Relay, LOW);
                        fan_status=0;
                for(int i=0;i<10;i++) code[i]=0;
                bytesread = 0;
            delay(600);                    // wait for a second
void dht_wrapper()
  DHT.isrCallback();
ANother issue is that, even through the fan/led turn on/off intermittently, the Particle does not Publish the message on Dashboard. It just gets stuck and publishes the event:
spark/device/app-hash53752DBA3712ED004266DCC7C73932990B
  • you should move the access key variables out of any function to make them global.
  • you should add a timeout variable that blocks the redetection of the last scanned card for a few seconds.
  • you should flush the serial buffer once you got a full key
  • in your code you need some logic to limit your publishing rate to 1 per second (with burst of four with an at least four sec pause), but in many cases you will violate the burst limit by attempting six or more publishes.
  • the way you compare your strings could be improved considerably by using strcmp(code, (const char*)accessKey) == 0). You just need to append a '\0' to your code[] in order to make it a C string.
  • why do you have two sets of includes for the same libraries?
  • memset(code, 0, sizeof(code)) is quicker than your for() to clear the code array, but since you are not using code and bytesread globally anyway, having them local would rid you of the need to clear them completely
    Maybe just write
  char code[11] = "";
  int  bytesread = 0;
  • spark/device/app-hash 53752DBA3712ED004266DCC7C73932990B is the response that you have just flashed new code successfully
With this MFRC-522 RFID reader.
Can we use any RFID card or does it need to be only the ones that come with the hardware ?
I have tried to read a key fob that I use to access a dor but it does not read it so that is why I am asking this question.
AFAIK there are different kinds of NFC cards - you’d need to look at the readers datasheet which kinds are supported and check if your key fob is compatible.
Hello ScruffR.
I had a look at the MFRC522 datasheet but could not find that information.
Do you know where is that information? As I would like to buy key fobs but I want to make sure they are compatible with the reader before.
Have you looked at this datasheet?
http://www.nxp.com/documents/data_sheet/MFRC522.pdf
