I’ve looked at the example in https://github.com/particle-iot/device-os/pull/1365, but I’m too new to fully understand what needs to change in my code to support the new method.
These publish events are failing - i"ve tried these variations on the publish event, but they all fail to compile and returns the seemingly infamous error:
_"CloudClass::publish(const char*, const char*)’ is deprecated: _
Beginning with 0.8.0 release, Particle.publish() will require event scope to be specified explicitly. Define PARTICLE_USING_DEPRECATED_API macro to avoid this warning."
Here are my examples I’ve tried.
Particle.publish(“StartTime”,String(startTime));
Particle.publish(“StartTime”,String(startTime),60);
Particle.publish(“StartTime”,String(startTime), MY_DEVICES);
Particle.publish(“StartTime”,String(startTime), 60, MY_DEVICES);
All of them fail to compile (I have several of these publish events). I don’t understand what I need to do about “const char* const char*” error messages…this code used to work…would love an explanation about the error and what I can do to fix this.
