WebIDE & Struct?
Are structs not working in the WebIDE? I know that with the Arduino IDE, struct definitions have to go into a header, but I can’t do that with the WebIDE:
// LIB1.H FILE
struct test{
  unsigned long id;
  char* label;
// CPP FILE
#include "lib1.h"
int getEventData(test& e) {
	return  0;
Errors encountered:
the_user_app.cpp:3:18: error: ‘test’ was not declared in this scope
the_user_app.cpp:3:24: error: ‘e’ was not declared in this scope
the_user_app.cpp: In function ‘int getEventData(test&)’:
the_user_app.cpp:4:25: error: ‘int getEventData(test&)’ redeclared as different kind of symbol
the_user_app.cpp:3:5: error: previous declaration of ‘int getEventData’
Try using a typedef
typedef struct {
  unsigned long id;
  char* label;
} test_t;
int getEventData(test_t & e) {
or with what you had…
 int getEventData(struct test & e) {```
Thanks @david_s5 One more: Any idea on how to adapt this:
union genieFrame{
uint8_t bytes[GENIE_FRAME_SIZE];
genieFrameReportObj reportObject;
Nothing I seem to try works.
Hi @ClintonKeith
Have you seen this thread on the same subject?
@bko, apparently not but thanks for pointing it out!
