Webhook with Azure SAS token for IoT Hubs
Using the built in Webhook feature of generating an Azure SAS token on-the-fly (https://docs.particle.io/guide/tools-and-features/webhooks/#azure_sas_token) work fine in combination with Azure Event Hub.
Used with an Azure IoT Hub it responds with error “IOT hub does not correspond to host name”
The endpoint url structure and hostname differs between the two types:
IoT Hub : https://xxxxxx.azure-devices.net/devices/mydevice/messages/events
Event Hub: https://xxxxxx.servicebus.windows.net/myeventhub/messages
One idea is that the problem has something to do with how the webhook sas token function parses the URL getting the scope needed.
Or could there be any other issue causing the problem?
Also, it would much appreciated if anybody from particle could describe how the Azure SAS token function works, especially related to extracting the scope from the URL.
I did several experiments concerning this and finally ended with the same result: “IOT hub does not correspond to host name”.
What I also metnion is that if I use the pattern https://{IoTHubName}.azure-devices.net/devices/{deviceId}/messages/events?api-version={api-version} (see https://msdn.microsoft.com/en-us/library/azure/mt590784.aspx) with non-existing deviceId, the hook finishes with the result like “device id does not exist in IoTHubName”. Thus it seems IoT Hub is reachable and communicates “somehow”. However, if I use existing deviceId, I end with “IOT hub does not correspond to host name”,
I have also found some similar issues concerning Azure IoT Hub REST API here: https://social.msdn.microsoft.com/Forums/sqlserver/en-US/5fad3240-3f0e-4695-8ea8-6b59ca646465/iot-hub-rest-api-error-message?forum=servbus
And here is piece of code returning this kind of error message in some SecurityHelper method validating IoT Hub name: https://github.com/Azure/azure-iot-sdks/blob/master/csharp/service/Microsoft.Azure.Devices/Common/Security/SecurityHelper.cs
So, lets open a discussion concering this issue, the goal is clear: “prepare easy-to-use solution for publishing/receiving messages to/from Azure IoT Hub via Webhooks and Particle devices”.
Trying to find some help here: https://twitter.com/JirkaKoutny/status/709752724989075456
Thanks a lot for your attention,
J.
Got it working, more or less. Consider this, especially headers section.
"event": "AzureEventHubWebhook",
"url": "https://{IoTHubName}.azure-devices.net/devices/{deviceId}/messages/events?api-version=2016-02-03",
"requestType": "POST",
"headers": {
    "Authorization": "{SAS}"
"json": {
"subject": "{{s}}",
"unitofmeasure": "{{u}}",
"measurename": "{{m}}",
"value": "{{v}}",
"organization": "{{o}}",
"displayname": "{{d}}",
"location": "{{l}}",
"timecreated": "{{SPARK_PUBLISHED_AT}}",
 "guid": "{{SPARK_CORE_ID}}"
"mydevices": true
Yes it works. However, SAS is fixed - I mean, SAS is comupted somewhere else and is filled in the webhook. My idea is to have support for computing SAS inside Webhook infrastructure based on Policy name and Key.
Setting the SharedAccessSignature statically in the Authorization http header works fine. But that would require a long expiration time in a real world scenario.
I think that one solution might be for particle adding an optional scope parameter to the webhook azure_sas_token function where it would be used instead of getting it by parsing the url.
Anybody from Particle that can comment on this?
So I’m currently trying to do this as well, but I’m just getting an error hook-error/{event}/0 with no content in the data. Anyone experience this?
And from here I went ahead and wanted to look at what my actual request looked like:
Unfortunately Azure IoT Hub doesn’t seem to have a nice way to just view errors thrown (that would make this a lot easier). When I setup diagnostics, nothing is being stored from the failed requests. Going to keep digging, but thought I would ask in case someone has seen this.
@jirkakoutny I think I got my part figured out through deep diving into Azure, but SAS token is messing me up. How do you generate your SAS token for the Photon? Do you use the Azure SDK on some other client and then pass the parameter into the url?
Hi All,
Sorry I didn’t see this thread earlier. It was my understanding that Azure IOT Hub expected a unique SAS key per device, and some special registration step. I haven’t had time to add special support for that particular service, and the Event Hubs auth token tends to work for most.
We generate the azure sas token by using Microsoft’s prescribed signed authentication header formula.
Essentially it’s this:
#pseudocode:
1.) create a timestamp sometime in the future (usually about an hour)
2.) URL encode the target url, include the expiration time.
3.)  Create a sha256 hmac using the azure sas key as the key.  Use the encoded URL + time as the plaintext, grab the signature of that hash.
The auth token is then:
 "SharedAccessSignature "
	+ "sr=" + url encoded url
	+ "&sig=" + url encoded hash signature
	+ "&se=" + expiration timestamp
	+ "&skn=" + name of azure sas key
David
Thanks for replying @Dave.
I think that the reason this is only working with older Azure EventHubs and not the newer eventhubs in Azure IoT Hub is that the webhooks built in “azure_sas_token” functionality are parsing the destination URL and making assumptions on its structure. See my first post in this thread.
If you have the opportunity please look into this again :smile: Thanks.
@vandelay - I’m trying to set up a webhook to Azure also. Not having much luck. Did we find a solution? (i’m very new to all of this so apologies if I’m missing the blindingly-obvious).
There is also no mention of an azure sas token in the guide you have provided
As far as i understand it the same still applies. The particle built-in webhook functionality to generate the SAS token on the fly (runtime) only works with Azure Event Hubs and not with the Eventhub in Azure IOT Hub.
To get it working i had to generate the SAS token offline (devtime) and then statically insert it in the http header “Authorization” which is only ok for testing. Se example further up in this thread if you want to try that.
The real solution would probably require Particle to change their “azure_sas_token” function and make it more configurable. @Dave ?
I see. Thanks @vandelay and @dave for all of the info!
Can you do that on the Particle @Dave ?
Hi @mterrill,
If you’re looking to create a webhook that feeds events into Azure Iot Hub, try our new Azure integration:
https://console.particle.io/integrations/azure-iot-hub/create
David
Hi @Dave, but you know I’d prefer being able to do SSL (particularly AWS HTTP gateway) and this type of computation on box!
Hi @mterrill,
Hmm, sorry, there wasn’t much context there, it sounds like you want to generate the Azure SAS token on a device like a Photon / Electron?
I haven’t tried this personally, but it looks like someone published an Azure utilities library:
AZURE_C_SHARED_UTILITY
In there I noticed “SASToken_Create” https://github.com/dcristoloveanu/azure-c-shared-utility-particleio/blob/master/firmware/sastoken.h
Maybe that’ll help?
David
