I have been playing around with Azure IoT and various other web services but getting rather frustrated with all the setup and costs. All I need is table data logging for remote sensors. No fancy integrations, management, or visuals.
The Azure function seems like a perfect fit for this since it can trigger on HTTP POST and write directly to the database. AND the first 1,000,000 executions are free.
So, has successful done this chain. Webhook -> Azure Function -> SQL database (preferred) or blob. and if so would they mind sharing the Function code, any code base is fine (#NET, node.js). Starting from example is always much easier.
VERY roughly.
Step 1. Setup Azure Function app to trigger on HTTP and output to HTTP and Azure Table storage.
Step 2. Write small function to decode JSON and store in Azure data table
Step 3. Setup particle web hook pointing to Azure function app
Key parts are that the JSON from particle MUST match the receiving class. There might be a better way but this works for now.
So now i have data logging for pennies a month!
Function code:
#r "Newtonsoft.Json"
using System;
using System.Net;
using Microsoft.AspNetCore.Mvc;
using Microsoft.Extensions.Primitives;
using Newtonsoft.Json;
public class FixData
public string fixType { get; set; }
public string unix { get; set; }
public string lat { get; set; }
public string lng { get; set; }
public string accuracy { get; set; }
public string temp { get; set; }
public string battV { get; set; }
public string solarV { get; set; }
public class RootObject
public string eventName { get; set; }
public FixData fixData { get; set; }
public string coreid { get; set; }
public string published_at { get; set; }
public bool noDefaults { get; set; }
public class TableData //this gets written to table
public string PartitionKey { get; set; } //Device ID
public string RowKey { get; set; } //UNIX time
public static async Task<object> Run(HttpRequestMessage req, ILogger log, IAsyncCollector<TableData> LuminousCdata)
log.LogInformation("C# HTTP trigger function processed a request.");
//Partition JSON
string jsonContent= await req.Content.ReadAsStringAsync();
RootObject mydataPoint= JsonConvert.DeserializeObject<RootObject>(jsonContent);
//copy data to new structure
var newTableRow = new TableData();
newTableRow.PartitionKey = mydataPoint.coreid;
newTableRow.RowKey = mydataPoint.fixData.unix;
newTableRow.fixType = mydataPoint.fixData.fixType;
newTableRow.lat = mydataPoint.fixData.lat;
newTableRow.lng = mydataPoint.fixData.lng;
newTableRow.accuracy = mydataPoint.fixData.accuracy;
newTableRow.temp = mydataPoint.fixData.temp;
newTableRow.battV = mydataPoint.fixData.battV;
newTableRow.solarV = mydataPoint.fixData.solarV;
if (mydataPoint.eventName != "geolocate"){
return new BadRequestObjectResult("Not a geolocate");
}else{
await LuminousCdata.AddAsync(newTableRow); //write to Azure Table
return (ActionResult)new OkObjectResult($"Received data from {mydataPoint.coreid}");
Losant is pretty nifty but it starts at $100/month and climbs substantially after year 1. Business licenses start at $30K/yr. I’m developing for a small scale product with a simple web interface I’ve already written so those prebuilt type solutions are not economic to me. I like to control my own data.
Besides, I thought I would offer an alternative. Functions + Tables is probably the cheapest scale-able data logger I have seen yet.
