Just to find out more details, could you elaborate on the commands used to input / perform the webhook? Please share your curl or API commands. Thanks.
It appears that it is not possible to parse a top-level array that is returned in the message body of a webhook.
This syntax
{{#.}}{{ParameterName}}:{{Data}}
is correct. However, I believe it fails to work because in addition to the variables in the webhook response, the built-in variables like SPARK_EVENT_NAME are also available, and they are mixed together using Object.assign(). This means the top-level is no longer an array, it’s an object, with a weird mix of key/value pairs and array elements. But since it’s no longer an actual array, it can’t be iterated using {{#}}.
I wasn’t able to think of a reasonable work-around to this.
It appears that it’s valid to start a JSON string with square brackets (and some other tokens besides curly brackets). Should this be reported as a bug?
