Web IDE - including a library
I’m having a bit of trouble using the TimeAlarms library on the Web IDE. When I add the library automatically (via the “include in app” button) the program compiles fine:
#include "TimeAlarms/TimeAlarms.h"
When I try to create my own .h and .cpp file to include the library manually, I get compile errors:
#include "TimeAlarms.h"
(The reason why I want to include the library manually is because I need to edit the .cpp file to allow for more alarms. The default is 6 for this library and I need 8.)
I am also using these two additional libraries:
#include "OneWire/OneWire.h"
#include "RCSwitch/RCSwitch.h"
I’m not quite sure what I am doing wrong. The same program runs fine when compiled via the desktop IDE however I’m having a bit of trouble getting things to work properly on the web IDE. Any help/ideas would be appreciated.
What’s the error output :o?
I’m not quite sure I’m understanding what it is telling me but here it is:
    TimeAlarms.cpp: In member function 'void AlarmClass::updateNextTrigger()':
TimeAlarms.cpp:62:48: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         if( value + previousMidnight(now()) <= time)
TimeAlarms.cpp:73:48: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         if( (value + previousSunday(now())) <= time)
In file included from TimeAlarms.cpp:27:0:
TimeAlarms.cpp: In member function 'AlarmID_t TimeAlarmsClass::alarmOnce(time_t, OnTick_t)':
TimeAlarms.h:20:44: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
 #define SECS_PER_DAY  (SECS_PER_HOUR * 24UL)
TimeAlarms.cpp:120:19: note: in expansion of macro 'SECS_PER_DAY'
      if( value <= SECS_PER_DAY)
TimeAlarms.cpp: In member function 'AlarmID_t TimeAlarmsClass::alarmRepeat(time_t, OnTick_t)':
TimeAlarms.cpp:136:18: note: in expansion of macro 'SECS_PER_DAY'
TimeAlarms.cpp: In member function 'time_t TimeAlarmsClass::getNextTrigger()':
TimeAlarms.cpp:326:31: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         return nextTrigger == 0xffffffff ? 0 : nextTrigger;
TimeAlarms.cpp: In member function 'AlarmID_t TimeAlarmsClass::create(time_t, OnTick_t, uint8_t, dtAlarmPeriod_t, uint8_t)':
TimeAlarms.h:23:44: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
 #define SECS_PER_YEAR (SECS_PER_WEEK * 52UL)
TimeAlarms.cpp:332:46: note: in expansion of macro 'SECS_PER_YEAR'
       if( ! (dtIsAlarm(alarmType) && now() < SECS_PER_YEAR)) // only create alarm ids if the time is at least Jan 1 1971
aquarium.cpp: In function 'void setup()':
aquarium.cpp:65:11: error: 'PWMCPIN' was not declared in this scope
 bool increment[3]={false,false,false};
aquarium.cpp: In function 'void loop()':
aquarium.cpp:143:11: error: 'PWMCPIN' was not declared in this scope
aquarium.cpp: In function 'int setPWM(String)':
aquarium.cpp:628:17: error: 'PWMCPIN' was not declared in this scope
   pwmState[0]=2; //set value to 2 for "off" position
make[1]: *** [../build/target/user/platform-6aquarium.o] Error 1
make: *** [user] Error 2
Error: Could not compile. Please review your code.
aquarium.cpp:2:35: fatal error: TimeAlarms/TimeAlarms.h: No such file or directory
That’s the one. If you include it through the library system, you need the ‘double’ name: “yadayada/yadayada.h”, whereas you’d need the single include if you include the files manually: “yadayada.h”
Give that a shot :)?
Sorry, I had posted the wrong output. I edited the post above just now to reflect the error output I get with the following includes:
#include "OneWire.h"
#include "RCSwitch.h"
The OneWire and RCSwitch both seem fine when I added them manually instead of through the system library. The TimeAlarms seems to be giving me the trouble.
With an empty sketch, including those files manually seems to work fine. Do mind the capitalization of the file names, they might make a difference.
It might be something in your code that’s being problematic.
Okay so it seems I caused my own error and it’s unrelated to the import. :grimacing:
Just problems with the rest of my program. All seems to be working now.
