I had a project that was freezing every now and then. I tried to find the cause but eventually added a Trinket to my circuit to reset my Core when it happened (super fun!). Once I got the timing correct, everything worked great with one exception, the Core can’t reset itself now. If I flash new code or my Core runs it’s periodic System.reset(), it will freeze and the trinket will eventually have to reset to Core. Everything works after the reset. If I flashed new code it stays solid magenta until reset. The new code runs once the Core gets going again. Is there something I can do to that will allow my Core to reset itself?
I’m running everything on 5v. The 5v Trinket looks for a signal from the Core’s A7 pin and pulls the reset pin low if too much time has passed. I added a the small capacitor on the reset/#2 line because the Trinket was resetting the Core during its setup().
Here is a picture of my setup if that is useful. Thanks for reading.
Thanks for the reply @kennethlimcp and sorry if I wasn’t clear.
The only connections to the Core are a string of WS2812B’s and the Trinket (Core’s A7 to Tinket #3, Core’s Reset to Trinket #2). I’m using “FastLED/FastLED.h” and running in automatic mode.
Not sure what you meant by watchdog preventing a software reset…
I’m using the Trinket to reset the Core in case it gets stuck. When I have the Trinket connected to the Core’s reset pin, I can’t Flash or do a System.reset() call. If I’m flashing new code, the Core will blink rapid magenta for a bit, disconnect from the cloud, then breathe magenta until the watchdog/Trinket 3 min timer kicks in and pulls the reset pin low. If the Core runs its periodic System.reset() call, the Core will hang there too - it will begin the reset, but not be able to complete the shutdown/restart and again the watchdog/Trinket timer will kick in and then the reset goes fine. The core is not running any code once I try the OTA flash or it runs its System.reset().
If I disconnect the Trinket from the Core’s reset pin, I can do OTA flash no problem. I suspect it would be able to do a System.reset() too. Hope that is clear. Thanks again for the reply.
Not sure why you hardcoded the Trinket to 3 minutes but what i would do is to use a digital pin from the core and toggle it digitalWrite(pin, !digitalRead(pin)). Once the trinket detects that the signal coming in is not toggling for more than…5-10 seconds, it will trigger a reset.
Of course this is not foolproof as during an OTA, user code stops running.
Can you explain more about why the Trinket needs to be there so that i can advice on how to change the user code and even remove the need for an extra Trinket?
This is what I’m doing with different timing. I toggle the Trinket pin every 5 seconds. If the Trinket doesn’t hear from the Core in 3 mins, it triggers the reset. This part all works great. My question is more about the hardware connection.
if ((millis() - lastTriggerTime) > 180000) {
digitalWrite(led, HIGH);
reset();
void reset() { // here is the reset function
digitalWrite(resetButton, LOW);
delay(1000);
digitalWrite(resetButton, HIGH);
delay(60000);
lastTriggerTime = millis();
Obviously for this interaction to work, I need a connection from the Core reset pin to the Trinket pin. I would like to know how to properly make that connection. Once I wire these two pins together, I can’t perform System.reset() call or complete at OTA flash without the Core freezing.
I think your problem is that you are driving the RST line to +5V when not reseting. You say above you are running everything on 5V but the reset input is a 3.3V input. It already has a 10K ohm pull-up and a 0.1uF cap to ground.
Do you have a 3.3V Trinket to test with?
Or a level-shifter?
Or just an NPN transistor (and invert the logic in the Trinket program)?
