The issue occurs with 4 variables.
Char* sensor_info_var (Stores sensor information in char)
String sensor_info_str (Stores sensor information converted from char* to str)
Char* RGB_info_var (Stores LED RGB information in char)
String RGB_info_str (Stores LED RGB converted from char* to str)
Somehow during publishing, the information in “RGB_info_var” is overflowed into “sensor_info_var”
NOTE: There’re way more code involved and it’s impractical to post all the code. It’s probably very unlikely to fully diagnose with partial code but It would be great if anyone could provide me with an insight on what could cause this issue!
const uint8_t NUM_OF_RGBS = 2;
const uint8_t NUM_OF_ULTRASONICS = 2;
const uint8_t NUM_OF_DHTS = 3;
const uint8_t NUM_OF_FANS = 6;
const uint8_t NUM_OF_NTCS = 7;
const uint8_t SENSOR_PUB_INTERVAL = 10-1;
time_t last_timer_checkin_time = 0;
uint8_t curr_bt[2][4];
uint8_t curr_rgb[NUM_OF_RGBS][3];
double curr_hsv[NUM_OF_RGBS][3];
uint8_t fan_spd[NUM_OF_FANS];
uint16_t fan_rpm[NUM_OF_FANS];
double dist_to_plant[NUM_OF_ULTRASONICS];
double ntc_temp[NUM_OF_NTCS]; //[front_LED, main_LED, rear_LED, water, peltier, pcb]
double dht_temp[NUM_OF_DHTS];
double dht_rh[NUM_OF_DHTS]; //[ambient, chamber, chamber_exit]
double PCBTemp = 0, AcColdTemp = 0, AcHeatTemp = 0, mainLEDTemp = 0, frontLEDTemp = 0, rearLEDTemp = 0;
int ac_status = 0;
int pump_spd = 0;
int day_length = 0, target_bt = 0, bt_fade_time = 0;
int airflow = 0;
int sunriseUnix = 0, sunsetUnix = 0;
double pltHeight = -1, frontPltHeight = -1, rearPltHeight = -1, waterTemp = -1, waterLvl = -1;
double chbTemp = -1, chbRH = -1, ambTemp = -1, ambRH = -1;
char *sensor_info_var = new char[512];
char *RGB_info_var = new char[64];
char *phase_info_var = new char[256];
String sensor_info_str = "{\"Not Available\": \"N/A\"}";
String phase_info_str = "{\"Not Available\": \"N/A\"}";
String RGB_info_str = "{\"Not Available\": \"N/A\"}";
void setup(){
Particle.variable("sensor_info_str", sensor_info_str);
Particle.variable("phase_info_str", phase_info_str);
Particle.variable("RGB_info_str", RGB_info_str);
void publishSensorInfo() {
Particle.publish("sensor_info", sensor_info_var, PRIVATE);
void update_senser();
// Updates all sesnor Info;
void loop(){
curr_time = Time.now();
update_senser();
sprintf(sensor_info_var, "{ \"fBTw\": %d, \"mBTw\": %d, \"rBTw\": %d, \
\"fBTc\": %d, \"mBTc\": %d, \"rBTc\": %d, \
\"af\": %d, \"wLvl\": %.1f, \"fHt\": %.1f, \"rHt\": %.1f,\
\"fTemp\": %.1f, \"mTemp\": %.1f,\"rTemp\": %.1f,\
\"wTemp\": %.1f, \"acHtTemp\": %.1f,\"acCdTemp\": %.1f,\"pcbTemp\": %.1f,\
\"aTemp\": %.1f, \"cTemp\": %.1f,\"ceTemp\": %.1f,\
\"aRH\": %.1f, \"cRH\": %.1f, \"ceRH\": %.1f,\
\"inFanS\": %d, \"outFanS\": %d,\"acFanS\": %d,\"vFanS\": %d,\
\"GlsClr\": %d, \"AcStat\": %d, \"pumpSpd\": %d}",
curr_bt[WARM_LED][FRONT_LED], curr_bt[WARM_LED][MAIN_LED], curr_bt[WARM_LED][REAR_LED],
curr_bt[COLD_LED][FRONT_LED], curr_bt[COLD_LED][MAIN_LED], curr_bt[COLD_LED][REAR_LED],
airflow, waterLvl, dist_to_plant[0], dist_to_plant[1],
ntc_temp[FRONT_LED_TEMP], ntc_temp[MAIN_LED_TEMP], ntc_temp[REAR_LED_TEMP],
ntc_temp[WATER_TEMP], ntc_temp[AC_HEAT_TEMP], ntc_temp[AC_COLD_TEMP], ntc_temp[PCB_TEMP],
dht_temp[0], dht_temp[1], dht_temp[2],
dht_rh[0], dht_rh[1], dht_rh[2],
fan_spd[ELEC_IN_FAN], fan_spd[ELEC_OUT_FAN], fan_spd[CHB_AC_FAN], fan_spd[VENT_FAN],
eglass_tp, ac_status, pump_spd);
sensor_info_str = String(sensor_info_var);
sprintf(RGB_info_var, "{\"TRGB\": \"%02X%02X%02X\", \"FRGB\": \"%02X%02X%02X\",\
\"THSV\": \"%.0f,%.2f,%.2f\", \"FHSV\": \"%.0f,%.2f,%.2f\"}",
curr_rgb[TOP_RGB][0], curr_rgb[TOP_RGB][1], curr_rgb[TOP_RGB][2],
curr_rgb[FRONT_RGB][0], curr_rgb[FRONT_RGB][1], curr_rgb[FRONT_RGB][2],
curr_hsv[TOP_RGB][0], curr_hsv[TOP_RGB][1], curr_hsv[TOP_RGB][2],
curr_hsv[FRONT_RGB][0], curr_hsv[FRONT_RGB][1], curr_hsv[FRONT_RGB][2]);
RGB_info_str = String(RGB_info_var);
if (curr_time - lastSensorInfoPub > SENSOR_PUB_INTERVAL){
publishSensorInfo();
lastSensorInfoPub = curr_time;
