Hi Guys,I am using my Spark Photon to do some test.The setup code is as below
char addr[16];
Serial.begin(115200);
delay(2000)
IPAddress localIP = WiFi.localIP();
while (localIP[0] == 0)
Serial.println("waiting for an IP address");
delay(1000);
Serial.print(localIP[0], DEC);
Serial.print('.');
Serial.print(localIP[1], DEC);
Serial.print('.');
Serial.print(localIP[2], DEC);
Serial.print('.');
Serial.println(localIP[3], DEC);
server.begin();
//Setup the Tinker application here
//Register all the Tinker functions
Spark.variable("getjson",json_tx_string,STRING);
Spark.function("digitalread", tinkerDigitalWrite);
Spark.function("digitalwrite", tinkerDigitalWrite);
Spark.function("analogread", tinkerAnalogRead);
Spark.function("analogwrite", particleToDuo);
before I changed the variable key to “getjson” , it was “mess” and it will return the right message when I use the url https://api.particle.io/v1/devices/xxx/mess?access_token=xxx
but after I changed it ,I got the message as{“ok”: false,“error”: “Variable not found”}when I used https://api.particle.io/v1/devices/xxx/getjson?access_token=xxx
even I changed the key back ,it couldn’t recover anymore. I just don’t know why!!!
