Utoa( ) in application.h? [Solved]
I am trying to port the Nextion arduino libs and they are calling utoa like so utoa(number, buf, 10);
I have been doing some research and it appears that utoa is from stdlib.h for arduino but utoa is non-ISO C function. How/where should I define this function? I have application.h included but I am guessing that because it is non-standard it wasn’t included in application.h. Thanks.
stdlib.h reference doc
In the header you can try to use the keyword extern and C to pull the C function prototype
example:
extern "C" char* utoa(int a, char* buffer, unsigned char radix);
and then call the function as you wish
That did it! Thanks…
@LukeUSMC did you finish this port and would it be something you could share? I just got 2 of these displays and was thinking I’m going to have to port this lib but it would be nice if I didn’t have to reinvent the wheel. :smile:
