@peekay123
I decided to give it a try this morning, here my results
First I decided to do it the clean way, creating a new folder, putting into
the GraphicTest.ino (from example folder) and in this new folder called u8glib and putting the u8glib library minimal structure into ie u8glib.cpp and u8gilb.h then a new subfolder clib containing all sources files
Opened spark-dev corrected #include "u8glib/u8glib.h" from .ino and shot a compilation
Atom out of date ? well I’m using latest spark-dev version ??
Ok forgot clean way, put all the files into the same folder, the .ino, u8glib.h, u8glib.cpp and all contained info clib folder. Corrected back #include from .ino to #include "u8glib.h" and also the one from u8glib.h to #include "u8g.h"`` instead of #include "clib/u8g.h"go to compile same atom error, ok without any descent error message, I decided to forgot IDE and go to particle-cli my project folder containing all the file is called u8gtest so went one folder up and issued aparticle compile p u8gtestok, got an error telling me it can't push u8g_font_data.c file to cloud, because it's too big (4Mo), So I splitted this file in 3 files calledu8g_font_data1.ctou8g_font_data3.cthen the file original fileu8g_font_data.ccontains 3 more include to the new filesu8g_font_datax.c`
let’s get a new try
hummm,
Compile failed - Compile failed ? yeah, what’s the problem ? I do not know because I don’t have any error message more than Compile failed
S:\Skydrive\devt\spark>particle compile p u8gtest
Compiling code for photon
Including:
S:/Skydrive/devt/spark/u8gtest/U8glib.h
S:/Skydrive/devt/spark/u8gtest/u8g.h
S:/Skydrive/devt/spark/u8gtest/GraphicsTest.ino
S:/Skydrive/devt/spark/u8gtest/U8glib.cpp
S:/Skydrive/devt/spark/u8gtest/chessengine.c
S:/Skydrive/devt/spark/u8gtest/u8g_bitmap.c
S:/Skydrive/devt/spark/u8gtest/u8g_circle.c
S:/Skydrive/devt/spark/u8gtest/u8g_clip.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_api.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_api_16gr.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_attiny85_hw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_common.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_fast_parallel.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_hw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_hw_usart_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_no_en_parallel.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_parallel.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_port_d_wr.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_ssd_i2c.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_st7920_custom.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_st7920_hw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_st7920_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_std_sw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_sw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_t6963.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_uc_i2c.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_atmega_hw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_atmega_parallel.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_atmega_st7920_hw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_atmega_st7920_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_atmega_sw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_i2c.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_io.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_msp430_hw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_null.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_raspberrypi_hw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_raspberrypi_ssd_i2c.c
S:/Skydrive/devt/spark/u8gtest/u8g_com_std_sw_spi.c
S:/Skydrive/devt/spark/u8gtest/u8g_cursor.c
S:/Skydrive/devt/spark/u8gtest/u8g_delay.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_a2_micro_printer.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_flipdisc_2x7.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_gprof.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ht1632.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ili9325d_320x240.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ks0108_128x64.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_lc7981_160x80.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_lc7981_240x128.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_lc7981_240x64.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_lc7981_320x64.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ld7032_60x32.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_null.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_pcd8544_84x48.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_pcf8812_96x65.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_sbn1661_122x32.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1306_128x32.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1306_128x64.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1306_64x48.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1309_128x64.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1322_nhd31oled_bw.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1322_nhd31oled_gr.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1325_nhd27oled_bw.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1325_nhd27oled_bw_new.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1325_nhd27oled_gr.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1325_nhd27oled_gr_new.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1327_96x96_gr.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1351_128x128.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1353_160x128.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_64128n.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_dogm128.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_dogm132.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_lm6059.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_lm6063.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_nhd_c12832.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_nhd_c12864.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7687_c144mvgd.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7920_128x64.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7920_192x32.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7920_202x32.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_t6963_128x128.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_t6963_128x64.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_t6963_240x128.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_t6963_240x64.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_tls8204_84x48.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1601_c128032.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1608_240x128.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1608_240x64.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1610_dogxl160.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1611_dogm240.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1611_dogxl240.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1701_dogs102.c
S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1701_mini12864.c
S:/Skydrive/devt/spark/u8gtest/u8g_ellipse.c
S:/Skydrive/devt/spark/u8gtest/u8g_font.c
S:/Skydrive/devt/spark/u8gtest/u8g_font_data.c
S:/Skydrive/devt/spark/u8gtest/u8g_font_data1.c
S:/Skydrive/devt/spark/u8gtest/u8g_font_data2.c
S:/Skydrive/devt/spark/u8gtest/u8g_font_data3.c
S:/Skydrive/devt/spark/u8gtest/u8g_line.c
S:/Skydrive/devt/spark/u8gtest/u8g_ll_api.c
S:/Skydrive/devt/spark/u8gtest/u8g_page.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb14v1.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb16h1.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb16h2.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb16v1.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb16v2.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb32h1.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb8h1.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb8h1f.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb8h2.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb8h8.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb8v1.c
S:/Skydrive/devt/spark/u8gtest/u8g_pb8v2.c
S:/Skydrive/devt/spark/u8gtest/u8g_pbxh16.c
S:/Skydrive/devt/spark/u8gtest/u8g_pbxh24.c
S:/Skydrive/devt/spark/u8gtest/u8g_polygon.c
S:/Skydrive/devt/spark/u8gtest/u8g_rect.c
S:/Skydrive/devt/spark/u8gtest/u8g_rot.c
S:/Skydrive/devt/spark/u8gtest/u8g_scale.c
S:/Skydrive/devt/spark/u8gtest/u8g_state.c
S:/Skydrive/devt/spark/u8gtest/u8g_u16toa.c
S:/Skydrive/devt/spark/u8gtest/u8g_u8toa.c
S:/Skydrive/devt/spark/u8gtest/u8g_virtual_screen.c
pushing file: S:/Skydrive/devt/spark/u8gtest/U8glib.h
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g.h
pushing file: S:/Skydrive/devt/spark/u8gtest/GraphicsTest.ino
pushing file: S:/Skydrive/devt/spark/u8gtest/U8glib.cpp
pushing file: S:/Skydrive/devt/spark/u8gtest/chessengine.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_bitmap.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_circle.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_clip.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_api.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_api_16gr.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_attiny85_hw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_common.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_fast_parallel.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_hw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_hw_usart_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_no_en_parallel.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_parallel.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_port_d_wr.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_ssd_i2c.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_st7920_custom.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_st7920_hw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_st7920_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_std_sw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_sw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_t6963.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_arduino_uc_i2c.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_atmega_hw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_atmega_parallel.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_atmega_st7920_hw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_atmega_st7920_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_atmega_sw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_i2c.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_io.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_msp430_hw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_null.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_raspberrypi_hw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_raspberrypi_ssd_i2c.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_com_std_sw_spi.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_cursor.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_delay.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_a2_micro_printer.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_flipdisc_2x7.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_gprof.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ht1632.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ili9325d_320x240.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ks0108_128x64.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_lc7981_160x80.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_lc7981_240x128.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_lc7981_240x64.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_lc7981_320x64.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ld7032_60x32.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_null.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_pcd8544_84x48.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_pcf8812_96x65.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_sbn1661_122x32.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1306_128x32.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1306_128x64.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1306_64x48.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1309_128x64.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1322_nhd31oled_bw.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1322_nhd31oled_gr.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1325_nhd27oled_bw.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1325_nhd27oled_bw_new.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1325_nhd27oled_gr.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1325_nhd27oled_gr_new.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1327_96x96_gr.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1351_128x128.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_ssd1353_160x128.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_64128n.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_dogm128.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_dogm132.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_lm6059.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_lm6063.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_nhd_c12832.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7565_nhd_c12864.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7687_c144mvgd.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7920_128x64.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7920_192x32.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_st7920_202x32.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_t6963_128x128.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_t6963_128x64.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_t6963_240x128.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_t6963_240x64.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_tls8204_84x48.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1601_c128032.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1608_240x128.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1608_240x64.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1610_dogxl160.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1611_dogm240.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1611_dogxl240.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1701_dogs102.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_dev_uc1701_mini12864.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_ellipse.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_font.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_font_data.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_font_data1.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_font_data2.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_font_data3.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_line.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_ll_api.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_page.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb14v1.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb16h1.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb16h2.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb16v1.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb16v2.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb32h1.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb8h1.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb8h1f.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb8h2.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb8h8.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb8v1.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pb8v2.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pbxh16.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_pbxh24.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_polygon.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_rect.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_rot.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_scale.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_state.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_u16toa.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_u8toa.c
pushing file: S:/Skydrive/devt/spark/u8gtest/u8g_virtual_screen.c
Compile failed - compile failed
I think I will leave for now, without any clues on what’s going wrong due to missing descent error message. It remind my some VB6 generic error code some years (too much) ago
You know guys, I love Particle devices, but each time I want to do a library port, it’s really a pain in term of where files need to be located, which are pushed to cloud for compilation and which not . I think we reach the limits of “blind cloud” compilation for this kind of libraries ;-(
