Hi @hootie81, thanks for the reply. I’ll attempt to rewrite your code to get it working for TCP.
Here’s the Serial response I get from the server (currently I’m just reading my bitmap from a pastebin):
HTTP/1.1 200 OK
Date: Thu, 16 Oct 2014 10:48:44 GMT
Content-Type: text/plain; charset=utf-8
Connection: close
Set-Cookie: __cfduid=d428a2018229b075d16d28abaf2e9f4291413456524239; expires=Mon, 23-Dec-2019 23:50:00 GMT; path=/; domain=.pastebin.com; HttpOnly
X-Powered-By: PHP/5.5.5
Set-Cookie: cookie_key=1; expires=Thu, 13-Nov-2014 10:48:44 GMT; Max-Age=2419200; path=/; domain=.pastebin.com
Set-Cookie: realuser=1; expires=Fri, 17-Oct-2014 10:48:44 GMT; Max-Age=86400; path=/
Vary: Accept-Encoding
Server: cloudflare-nginx
CF-RAY: 17a3af8ab53e0b7b-LHR
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x07,0xff,0xff,0xff,0xff,0x00,0x01,0xff,0xff,0xff,0xf8,0x01,0xff,0xff,0xff,0xff,0xc0,
0x07,0xc0,0x00,0x00,0x1f,0x00,0x3f,0xff,0x80,0x00,0xf8,0x01,0xf0,0x00,0x00,0x07,0xc0,
you get the idea.
